RM European Auto Parts
Results 1 to 8 of 8
Thread: E46 330ci vibration under load
    Feb 2015
    New Jersey
    e34 525i 5spd
    I just bought an e46 around 800 miles ago at around 85k miles. It needed a new center support bearing when I bought it, and I replaced that and the guibo. That got rid of a lot of the banging and vibrating that was present, but not all of it.
    Now, around 2500 rpm in mostly second, third, and fourth gear, the car vibrates from what seems like the area of the center support bearing. I know the car needs a new wheel bearing on the driver rear wheel but don't think that could be my problem. I don't really know what to check to alleviate the problem so any guidance in the right direction would be very helpful.
    Thanks.
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Typically if the csb is bad the driveshaft isn't far behind. Most recommend replacing the driveshaft (which includes a new csb). I had the exact same issue on my 330 recently and a new driveshaft fixed the issue.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    +1. The CSB dies in conjunction with the u-joints / cv joints of the driveshaft. Installing a CSB is like putting a band-aid on a stab wound.
    I recommend:
    http://www.driveshaftspecialist.com/...0html/BMW.html
    Chris Powell
    BMWCCA 274412
    Feb 2015
    New Jersey
    e34 525i 5spd
    Ah, not the best news but could be worse. Is it normal for the driveshaft to have already started failing at 85k miles? I initially thought that there was a different problem which caused the driveshaft to vibrate excessively and the CSB to go out, so in a way I guess I could be right. Is the old driveshaft with a new CSB worth anything or should I just scrap it?
    Thanks, both of you.
    Jun 2002
    E39M5, E500 4WD
    You'll need to send the old driveshaft to the company from whom you buy your replacement. The supplier will provide you with a UPS return label with the new unit, so you can return the core.
    Chris Powell
    BMWCCA 274412
    Feb 2015
    New Jersey
    e34 525i 5spd
    Alright. Since I have made the post I feel I should include a few more things. The problem is totally resolved under light throttle, no vibration at all. When it is in gear and no throttle, the vibration is sortof apparent, noticeable but nothing crazy. It is at its worst when I get on the gas to accelerate suddenly, like merging onto the highway. I have noticed that the vibration is less apparent when I slowly climb in rpm, so if I was in third gear and gave it light throttle to around 3500 rpm, it will still vibrate but not as bad as if I was at 1500 rpm and gave it heavy throttle to 3500.
    The vibration is also not present in the shifter which leads me to believe something else might be at fault, but I don't really know, maybe the trans mounts are super effective.
    Thanks for the help
    Dec 2013
    Chicagoland area
    EXOTICS
    Check motor mounts in addition to transmission mounts.
    Mar 2003
    St. Joseph, Mo.
    From my spot - and I'm not in front of th car obviously - this information just matches even more with driveshaft.
    If you want to be certain have it diagnosed by a pro.
  1. Help, Vibration under load
    By Cristian Silva in forum 1991 - 1999 (E36)
    Last Post: 05-29-2011, 11:24 PM
  2. E46 tinsle/vibrating under WOT
    By euro96 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-17-2009, 02:45 AM
  3. Strange Vibration Under Load
    By 544iAe39 in forum 1996 - 2003 (E39)
    Last Post: 02-13-2009, 02:57 PM
  4. 330ci vibration under hard acceleration
    By 5timesrafa in forum 1999 - 2006 (E46)
    Last Post: 02-13-2007, 03:09 PM
  5. 90 535ia vibration under load??
    By Guelphguy in forum 1996 - 2003 (E39)
    Last Post: 11-18-2004, 11:17 PM
