E36 Active Autowerks differential support brace
Hey guys up for sale I have an Active Auto DSB sprayed flat black to blend in a little more with the undercarriage decent shape.Its used obviously.
Info from AA DSB :
There's a reason we've sold hundreds of E36 front differential mounting bolts - they break.
Failure is at a minimum inconvenient - you're stuck on the side of the road or left sitting out at the track. In some cases, differential damage occurs, involving significantly more expense than the hours involved in pulling the differential to extract the broken bolt.
Active Autowerke to the rescue with their DSB! In gorgeous green finish, this support bracket provides reinforcement for the front bolt, virtually eliminating failure in even high horsepower vehicles with abused drivelines. DIY, bolt-in installation can be completed in less an an hour.
A must have for all E36 325, 328, and M3 owners!
Not for use with aftermarket/performance differential bushings with a flange that protrudes further than OEM.
List Date: 7/18/2017
For more info, click here to view the original listing: E36 Active Autowerks differential support brace
SOLD
