Results 1 to 5 of 5
Thread: Is this the correct amount of coolant ?
    Dec 2016
    Plano, TX
    BMW 335i convertible
    It's a 2011 335i manual. I don't know when the dip stick was damaged or gone, so I used to measure the level by the min and max Mark inside.
    Today I got my car back from the dealer after regular maintenance and noticed they topped up coolant till the filler up which is much above than the max Mark. So I removed coolant and it was like appx a quart and made the level near the max mark.
    Am I doing something wrong or it's the dealership who messed up?
    Sent from my SM-G935F using Tapatalk
    Dec 2016
    Plano, TX
    Oh, forgot to mention - I checked the coolant when it's cold. Car was in my garage whole night and then checked in the morning
    There is no dipstick. You are using the correct method to determine the level. When cold, it should just cover the yellow thing in there that says min/max.
    If you pulled out a full quart, then whoever serviced your car is a dumbass. Or just doesn't know any better. A lot of rookie tech's just fill the reservoirs to the top, leaving no room for expansion (hence the name, expansion tank).
    Dec 2016
    Plano, TX
    Quote Originally Posted by White94RX View Post
    Thanks.
    Yeah, I was quite surprised seeing the dealer invoice where they did complementary fluid top up. When I saw they mentioned coolant, I immediately checked as I flushed my system a month back.
    I took out almost a quart and now the level is just a little below max. Drove the car for 30 mins and then checked next morning, and it's on the perfect spot.
    Jul 2015
    US
    325i
    Interesting, my 328i has a dipstick, also a 2011
  1. Is this the only amount of trim I need to remove to access RSMs?
    By CaliAgents in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-04-2005, 11:35 AM
  2. Replies: 1
    Last Post: 09-25-2004, 11:40 AM
  3. Is this the correct wheel size?
    By toropoki in forum 1995 - 2001 (E38)
    Last Post: 06-09-2004, 10:29 AM
  4. is this the correct AA turbo for my car?
    By ReVsHoT in forum Forced Induction
    Last Post: 05-11-2004, 08:24 AM
  5. Is this the correct auxiliary fan?
    By Mini-Bubba in forum 1992 - 1999 M3 (E36)
    Last Post: 11-02-2003, 12:23 PM
