RM European Auto Parts
Results 1 to 25 of 28
Thread: ABS rebuild still no speedometer/ABS
    Jul 2017
    Bloomington, MN
    2000 5 series
    Sent the ABS module to module masters for rebuild. They could not find anything wrong with it, other than a code 23 incorrect coding issue. Sent back, no charge for repairs. Stated to drive and see if it fixed itself. The speedo has worked intermittently, odometer the same, abs light still on along with the traction light on dash board. Took to mechanic and got the following codes from computer. Engine controller 12, transmission controller 12, 420 fault, 430 fault, and catalytic converter efficiency code. I know the 420, and 430 ore O2 sensor issues.
    So question is, is there anything else that would be causing the speedo, odo, and ABS to not work? Everything I have read pointed to the ABS module. If a Com error, can I get current one reprogrammed, or do I need to replace old, and then reprogram new one from MM? Not really too concerned about ABS but really want Speedo/odo working again, would be nice to get it all fixed tho!
    2000 5 series BMW
    Must say Module Masters have been awesome trying to help out with this is well. HIGHLY RECOMEND THEM!!
    Jul 2004
    Houston, TX
    36 Cylinders
    You should get the codes read out of the DSC module, not out of the engine control module. Sounds like your mechanic missed this one too. It will tell you the complaint.
    DO NOT GUESS. The car literally tells you what is wrong if you ask it.
    Highly likely that your Rear **LEFT** [edit] wheel speed sensor is bad, as it's involved in speedometer reading.
    Also, DSC/ABS codes in your car are read from the under the hood 20-pin port ONLY.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Yep, I too recall right rear ABS sensor being responsible for speed values. You should ohm out your sensors from the glove box connections.
    NW suburban Chicago
    hiss by my window
    He's in Minnesota so also a fair chance that the connector in the wheel well is rotten. Could they have put it in a worse spot?
    Jul 2017
    Bloomington, MN
    2000 5 series
    Thanks, will stop by the mechanic tomorrow, see what we can figure out. Have replaced the Driver side rear sensor already, will look at the right side.
    Jul 2017
    Bloomington, MN
    2000 5 series
    Where in the engine compartment is the 20 pin connector located, had my son take to mechanic, apparently they could not locate it couple days ago. Guy does not work on BMW very often....
    Jul 2017
    Bloomington, MN
    2000 5 series
    Where in the engine compartment is the 20 pin connector?
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by ddietz336 View Post
    Well then he shouldn't be working on your BMW now!
    I understand trying to avoid BMW dealership diagnostic & repair costs,
    but having repairs done that you are not able to DIY, should really be handled by a BMW specialist shop.
    Jul 2017
    Bloomington, MN
    2000 5 series
    Thanks for no help. I am more than capable of fixing it, just not going to spend 5K on a diagnostic tool. Appreciate it. And yes not going to a $100/hr bmw shop to tell me it is a $20 part that can be replaced in 20 minutes. I have already done the left side rear sensor, just want to know for sure what the issue is before I take things apart.
    It was a simple question, just need a little direction.
    Dec 2013
    Chicagoland area
    EXOTICS
    Highly likely that your Rear Right wheel speed sensor is bad, as it's involved in speedometer reading.
    Direction has already been given, my last post was just an attempt to provide a quick end to the mystery, sorry.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    +1.
    The best damned BMW computer guy on these forums told you what you needed to do to diagnose the issue. You're unwilling to take it to a BMW pro, or someone who has a diagnostic computer that can talk to your ABS computer. Therefore, you can't fix it, because you can't diagnose it.
    There's your simple answer to your simple question.
    Chris Powell
    BMWCCA 274412
    Feb 2009
    KC North, MO, USA
    1996 740iL
    If you didn't replace your wheel speed sensor with a Siemens, it would do exactly what you are reporting. I can't tell you how many of these we see in the E38 forum, which run the same DSC module.
    Dec 2013
    Chicagoland area
    EXOTICS
    +1
    Definitely replace with Genuine BMW OE or Siemens OEM,
    basically any sensor must be OE or at the very least OEM,
    unless you enjoy chasing down electronic anomalies.
    This may be one of them circumstances!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    OP, people are trying to help you. Me too. Try this.
    88M3 AW 43k miles Project FS
    Jul 2017
    Bloomington, MN
    2000 5 series
    Sorry for the earlier rant, first BMW owned, it is my sons car. I have worked on many cars over the years but these BMW's are aggravating. I did replace the left rear sensor previously, but used one I got from Rock Auto, was not an OEM or Siemens.
    Two quick questions, can a standard diagnostic computer, ,with a 20 pin adapter read the codes. Hooked up to three different computers and was unable to connect. Also the RIGHT rear wheel sensor is for the speedo and odo correct?
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    when you say a "standard diagnostic computer" what do you mean?
    whatever you hook up to the car will likely need BMW specific software to function - and certainly with the 20 pin connector that would be the case.
    Jul 2004
    Houston, TX
    36 Cylinders
    If you or your son is good with windows computers, follow the instructions in this first post of my thread here http://www.bimmerforums.com/forum/sh...xperimentation to make your own good diagnostics computer.
    You would need the USB-OBD cable with the 20-pin adapter I have linked (or similar).
    BMWs are not frustrating at all once you see how they approach things, especially these older ones. The electronics give you so much information to guide your repairs. No reason to be aggravated about it.
    -Abel
    Jul 2017
    Bloomington, MN
    2000 5 series
    Quote Originally Posted by shadowpuck View Post
    Hooked up to 2 snap on diagnostic computers and do not recall the third one. Standards as in 16 pin under dash diagnostic imputers. Not BMW specific.
    Jul 2004
    Houston, TX
    36 Cylinders
    Again, only the engine control module and transmission control module are wired to the OBD port inside the car.
    To reach ABS/DSC and all other modules you need to use the 20-pin adapter under the hood.
    The Snap on should work, although it isn't a terribly good tool for BMW use.
    -Abel
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    I have uses several different models of the snap-on box/brick and with the correct adapter, they will talk to the ABS/DSC module.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    listen to abel (328 power 04) - he absolutely knows what he is talking about. the link he provided is OUTSTANDING and will shave many hours off setting up your own machine.
    as he points out - if you are connecting to the 16 pin OBD-II port on this car, you aren't going to get much except OBD-II codes. everything else is run through the 20 pin connector under the hood. If you have a diagnostic machine with BMW software, then it should be able to talk on the 20 pin connector (or the pac man as many call it).
    agreed - bmw's seem very logical to me, but i don't work on many other cars so i'd probably say the same about other makes!
    lots of great resources out there for an e39 5 series so don't get discouraged.
    +1
    red brick FTW! i have my own MT2500 that lives solely to talk to my e36 when its being snotty....i need to rebuild my INPA setup - i've messed around with it so much who knows what i've rearranged!
    Jul 2017
    Bloomington, MN
    2000 5 series
    Thanks guys, is the speedo tied to the left or right rear wheel sensor, have seen info for both sides.
    Mar 2003
    St. Joseph, Mo.
    should be left (driver) rear that drives speedo.
    there's also an amazing thread over on bimmerfest on troubleshooting this system for an e39 - suspect you may have already gone through all of their troubleshooting steps?
    Jul 2004
    Houston, TX
    36 Cylinders
    I always knew it as right rear... but if I am wrong, I would love to know, to correct my posts.
    -Abel
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Drivers side rear for speedo. Cruise uses passenger side.
    I'm not above sharing a link from another forum when it's as thorough as this one is.
    http://www.bimmerfest.com/forums/showpost.php?p=4205801
  1. ABS, and brake light, no speedometer
    By GATORSHOES in forum 1999 - 2006 (E46)
    Last Post: 09-01-2013, 02:17 PM
  2. ABS/DSC/No speedometer/No MPG indicator
    By udem2k in forum 1995 - 2001 (E38)
    Last Post: 10-11-2012, 03:50 AM
  3. No Speedometer, No DSC, ABS Light On
    By judbud in forum Pacific Northwest - US
    Last Post: 10-20-2008, 04:51 AM
  4. ABS Module rebuild yes/NO whats your vote?
    By E46E392001 in forum 1996 - 2003 (E39)
    Last Post: 05-21-2007, 09:00 PM
  5. ABS, BRAKE, Traction light on, No speedometer, MPG, odometer
    By JBizzel in forum 1996 - 2003 (E39)
    Last Post: 12-14-2006, 12:01 PM
