Results 1 to 4 of 4
Thread: E36 racecar 2.8L ITR/STU/GTS spec3? - No Longer Available
    Geigertown, PA
    95 M blk/blk
    I am selling my E36 road-race car as its not in the cards for me to have both a hillclimb car and a road racing car. Car started as a 328i and still has a 2.8L engine and was originally built for ITR but there are a few upgraded things that may put it in another class. Since there are still items like door glass, heater core and full wiring harness the car can fit into many different racing organizations. It has a SCCA log book. It was raced last in fall of 2016 so it has a current SCCA annual tech sticker. The only thing preventing it from being 100% race ready is the lack of a seat and harnesses. It seems a race ready entry level ITR car is about 10-12K so I have priced this at $9200.
    The interior of the car was painted to match the exterior and I feel it really makes the build much more presentable. There are a few scratches on the interior paint but overall it looks very good and neat. The exterior paint is fair although the hood is oxidized?but hey it?s a racecar! This would be a great starter racecar or a solid platform to pursue a GTS2 or STU build. Call Ken at 484-824-1661. Located in Morgantown, PA.
    Shell: 1996 328i
    IT legal 6 point cage + driver?s foot protection
    NASCAR bars on drivers side. Bars give MAXIMUM elbow room for driver as they extend so far outward they touch the outer door skin. Only driver door is gutted. Driver window is easily installed for transport and storage. Passenger power window still works.
    Dash bar goes THROUGH the heater box so it is straight with no bends
    Floor plates are thicker, 3/16"
    Welded-in bosses for belt anchors on both driver and passenger side. Two sets for different seating position on driver side.
    Car weighs 2860 lbs with 180 lb driver and 3/8 tank of fuel
    Engine 2.8L, stock M52 engine, M52 manifold and gearbox
    BW 3" race exhaust
    EPIC Tune: 180 WHP, 200 FT-LBS
    ZF trans
    SPEC clutch on stock DM flywheel
    BW solid engine and trans mounts
    SPAL fan
    BW dual fuel pump kit
    Suspension
    AST 4100
    Vorshlag camber plates
    Reinforced stock rear lower camber arms
    BW Solid subframe bushings
    NEW rear ball joints
    NEWER OEM axles
    New rear wheel bearings
    Poly RTAB
    Reinforced RTAB pockets
    Reinforced rear subframe
    Reinforced Rear sway tabs
    Turner Spherical rear upper inner bushings
    Poly front CAB
    Wheel studs
    (5) Kosei wheels
    3.15 LSD
    BW solid diff mounts
    Brakes
    M3 front and rear Brakes
    HAwk blue pads
    Brass caliper slides
    SS brake lines
    Needs a seat, harnesses and the shifter could use new bushings.
    List Date: 7/17/2017
    For more info, click here to view the original listing: E36 racecar 2.8L ITR/STU/GTS spec3?
    This item is no longer available.
    Geigertown, PA
    95 M blk/blk
    BYOS (bring your own seat) and have a raceready car! Finally found some race results from last year, I turned a 117.8 at Jersey lightning.
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Just FYI, 328 chassis are not legal for NASA Spec3. Would probably make a good donor for BMWCCA SpecE36, though. Good luck, looks like a nice build.
    Geigertown, PA
    95 M blk/blk
    Deposit taken!
    96 328i ITR Racecar
    2002 325XiT - daily
  1. E36 93 - 325is - Spec E36 Racecar
    By kolo1racer in forum Race Cars & Track Parts
    Last Post: 01-07-2011, 09:33 AM
  2. FS: 1992 BMW E36 Racecar. SCCA ITR
    By ChrisB41 in forum 3 series & Z Series
    Last Post: 04-07-2009, 02:59 AM
  3. 1992 BMW E36 Racecar. SCCA ITR
    By ChrisB41 in forum Race Cars & Track Parts
    Last Post: 04-05-2009, 06:50 PM
  4. S14 E36 racecar kicking everyones ass!
    By SDbboy in forum 1987 - 1991 M3 (E30)
    Last Post: 06-27-2004, 04:37 PM
  5. does anyone have pics of an E36 M3 with 18" BBS RS-GTs?...
    By m3j0n in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-15-2003, 09:35 PM
