Results 1 to 4 of 4
Thread: 96 328i Rk tuned.
    May 2017
    California
    96 328i E36
    96 328i Rk tuned.
    Hey guys I have a 96 BMW 328i. Car has a Rk tune reflash thanks to Jordan at RK. I have a A/C delete, PS delete, and CAI. I've had an intermittent starting issue since before the tune with codes p0170 p0173 p1188 and p1189 all fuel related CEL's. But after the tune I got CEL P0601. Something having to do with internal memory? I just wanted to know if it was a serious code car runs great performance wise. It's just the hard starts and CELs that scare me. Any advice would be greatly appreciated. Car also does surge during idle, I believe it's unrelated to the CEL's I think it's air in my brake line and a small vacum leak because when I pump my breaks constantly it idles steady.
    Jul 2004
    Houston, TX
    36 Cylinders
    Ask RK tunes if he corrected the Checksums on the tune.
    The rest you will have to tell us what other mods you have, and if you have vacuum leaks.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    So, um, what have you done to fix all the lean codes? You bought a tune, when you have a car that only idles well when you keep pumping the brakes?
    Hmmm.... P/S delete, A/C delete, Oiled cone, MAF destroying, water sucking, hot air kit. Tune that sets codes.
    Have you considered that you're going backwards?
    My best suggestion would be to fix the power steering, the a/c, and the intake leaks, put on the stock airbox. Then have someone fix the tune.
    Chris Powell
    BMWCCA 274412
    Dec 2013
    Chicagoland area
    EXOTICS
    How can you ignore all the intermittent starting issues and codes, and still proceed with a tune?
    Chris is right, your vehicles condition seems to be headed backwards,
    as you seem to be attacking performance issues in reverse order.
  1. Replies: 3
    Last Post: 02-10-2017, 06:51 PM
  2. E36 OR: 96 328is 5spd with cams, exhaust, tune
    By KyleAwesome in forum 3 series & Z Series
    Last Post: 05-29-2012, 03:33 PM
  3. 96 328is tecnique tuning stage 2 $8,500
    By option1283 in forum California sponsored by Avus Autosport
    Last Post: 05-20-2010, 03:18 PM
  4. Amp Tuning 96 328i
    By N23C in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-01-2006, 06:22 PM
  5. 96' 328i Tune up questions???
    By Dr.DukeRaul in forum 1991 - 1999 (E36)
    Last Post: 07-13-2006, 12:29 AM
