Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 13 of 13
Thread: OEM run flat replacement?
    Aug 2016
    Upstate NY
    Honda S2000, VW Jetta TD
    We picked up a CPO 2015 335xi manual w/ 25k miles and have put about 2K miles on it.
    We're both old enthusiasts w some track time ( I trail brake and H/T on the street, my wife not so much) but this car is our DD mule.
    OEM Pirellis are about half done. PO used snow tires in the winter, we'll be running all season RFT.
    ONLY THING I DONT LIKE ABOUT THIS CAR - is the tire noise on imperfect surfaces which are everywhere around here.
    Looking at early replacement but gotta believe there's something better than the OEM Pirellis.
    Thanks in advance for any experiences/insights/ recommendations
    Edmonton, Canada
    2012 550i x drive
    Quote Originally Posted by gerry1000 View Post
    That would be the 225/45/18? Which Pirelli's are on it? I think all RF are noisy but if you are on their P Zeros those are supposed to be one of the better RF out there. I did a lot of research before dumping the RF on my 5 Series. Bridgestone Driveguard or Pirelli P7s are highly rated RF tires at 225/45 including winter use. If the wheels would accommodate a 245/40 there are more options like Pilot Sports.
    Aug 2016
    Upstate NY
    These are P7s
    Edmonton, Canada
    2012 550i x drive
    These are P7s
    It might be just the runflat that doesn't feel right. P7s are a Tirerack recommended tire with above average performance but one of their weakest ratings is for noise (6.8 out of 10). The Bridgestone Driveguards are a Tirerack's class leader in 225/45 All Season RF with a noise rating of 8.3 and other strong performance numbers so if noise is the issue the difference should be substantial.
    Aug 2016
    Upstate NY
    Thanks, still gonna wear on the P7s til next year, then it looks like DriveGuards then
    Used to drive 40k a year for work, and remember noise getting worse as tires wore out. However I'm cheap enough to live with it
    Aug 2016
    Upstate NY
    New Driveguards All Seasons this week.
    Will try to remember to update with my impressions
    Aug 2016
    Upstate NY
    Had the All Season Driveguards put on this morning.
    Much quieter on the way home than the worn P7s
    Good test , as this is peak heave/pot hole season around here
    ( got these at my "go to" tire store as opposed to for same price at Dealer. Dealer had mis inflated tires before AND when they remounted after snows from previous owner they had a load of balance weights on them, a sure sign of inexperience. The sophisticated BMW suspensions and sensitivity to tires to me means that Dealer Techs are not up to the task)
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The Driveguards are the best riding run flat tire on the market. In our testing they handled better than the Conti's that BMW uses as well. I think you made a good choice.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Aug 2016
    Upstate NY
    Well, there is a twist in this tale.
    Returning from a trip this PM on the charming NYS Thruway one of the many potholes snuck up on me ( I think)
    Loud bang, LF warning light. We managed to limp the last 30 miles home.
    At home. we find the LF side wall split and a bulge in the bead of the LR. Tires have 800 miles on them.
    Anyway, towed to dealer where I'll request in addition to tires a full inspection of the wheels and underside of the car.
    Anything else I should check. Any other suggestions Jim@Tirerack.?
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Well, their is a twist in this tale.
    Returning from a trip this PM on the charming NYS Thruway on of the many potholes snuck up on me ( I think)
    The only other thing I can think of is the alignment. If it is two tires the onew we sell do come with a two year road hazard protection so if it were to happen again you are covered for the price of the tires.4C6A1FF651EE11E8AA59843DC6EB2E60
    2459@)@()%$)!@if I can help let me know.
    Aug 2016
    Upstate NY
    Two new tires AND two new wheels needed.
    Hell of a pothole.
    Underbody inspection OK. After Alignment a total of $2500 so far
    Aug 2002
    South Bend, Indiana
    BMW 525I
    If I can help with anything let me know.
    Aug 2016
    Upstate NY
    got the car back and seems that everything OK.
    I'll update the tire experience in the future
  1. Best non-Run Flat replacement tires for 07 530i
    By RossPirelli in forum 2004-2010 (E60,E61)
    Last Post: 02-28-2012, 08:16 AM
  2. WTB OEM Run Flats for E92 w/sport
    By Laze1 in forum Georgia sponsored by Harrison Motorsports
    Last Post: 02-02-2011, 09:17 PM
  3. 2008 OEM Run Flat Potenza tires
    By ML335i in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-02-2011, 04:55 PM
  4. New Bridgestone Potenza OEM Run Flat Tires
    By californiadream in forum Wheels and Tires
    Last Post: 11-02-2009, 12:12 AM
  5. Run Flat replacements 2004 Z4 3.0
    By GordM in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 04-08-2008, 05:31 AM
