Results 1 to 8 of 8
Thread: 1979 735i back on the Road
    Denmark
    520d G30
    Hi,
    This summer I will try to get my car back on the road. Yesterday we worked with and serviced the car.
    After a oil change with 15w40 I noticed that the oil lamp are really slow to turn off and if you push the test button while driving the test lamp are flickering. I have a e32 where the problem with the pressure were the oil canister but the E23 has a different design.
    What are the first step to get the lamp to turn off more quickly?
    1991 E32 750IL Highline Individual
    1987 Alpina B11
    Mar 2013
    USA
    E21/early e23/e34
    Nice car- Need more information, how long does it stay on, cold engine or warm engine, high miles or not???
    Most likely it's the oil pressure sensor at the back of the head, passenger side (single blade) these are known to fail. Very easy to replace and cheap, the oil pumps on the M30 motors are pretty stout and don't fail very often.
    I'd also rethink the oil you're using, these older BMW motors need to be run with the "dino" oil, has good amounts of zinc which is needed for engine wear protection, lots of info if you search.
    Post more images and details of the car, I also have a '79 e23 and would be especially be interested in engine bay images.
    Jun 2010
    TX
    1983/84/85 745i
    Hey, that sticker shows a 'Dog Leg' trans...is this in your car???
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Denmark
    520d G30
    This week I finally found time to change the brake booster - not so complicated as first expected but the bomb must wait for winter! Next thing is the brake fluid and to spare my marriage I have ordered a electric pump so I can tackle the job alone!
    The oil pressure sensor is lying and waiting to be changed..
    The seller I got the car from has this video on youtube of my car. I have though upgraded to leather that I found and picked up in Holland.
    1987 Alpina B11
    Denmark
    520d G30
    Could not resist installing one of the new French headlamps. Looks okay - right? :-)
    1987 Alpina B11
    Mar 2006
    Sacramento, CA
    87 535i/84 €735i/8
    Good looking car.
    --Jay3->Sic gorgiamus allos subjectatos nunc
    84 €735i manual, 88 528e/i
    Motronic 1 and 1.3 wiring
    Transmission & Diff gearing sheet
    Jun 2012
    Northern Ireland
    E23 732i E38 740 Z3 3.0
    Quote Originally Posted by mop007 View Post
    Hi,
    It's not a problem, as long as the light goes out. There are two pressure switches on these engines, and when the same thing happened to mine, I got my local BMW garage to swap them out. it didn't solve the problem, so the only thing left was the oil pump. Swapped it out, and the problem remained. The following month, I picked up BMW Car magazine, which had a feature on the E23, and it actually referred to the lazy oil light, and said it was nothing to worry about. I was £300 poorer, and to think that the BMW garage didn't already know about it!
    Denmark
    520d G30
    Thank you.. It is a pain to look at the oil lamp until it turns off :-)
    1987 Alpina B11
  1. E32 735i RHD/5sp 1987 - back on the road project update
    By croolis in forum 1988 - 1994 (E32)
    Last Post: 08-04-2011, 02:53 AM
  2. Another 02 back on the road (OT)
    By FlyingHigh in forum 1995 - 2001 (E38)
    Last Post: 02-09-2004, 03:29 PM
  3. New setup!!! Will be back on the road soon
    By aMiR M3 in forum Forced Induction
    Last Post: 11-24-2003, 11:20 AM
  4. Back on the road again!
    By Carzzi in forum 1992 - 1999 M3 (E36)
    Last Post: 11-04-2003, 01:22 PM
  5. Back on the road and dyno.
    By Gday mm8 in forum Forced Induction
    Last Post: 08-16-2003, 12:12 AM
