so the circuit board is part of the tail light and i have to buy a new tail list lens/ circuit board ?
there is power to the circuit board but there
is bad contact to the lamp holder.
i replaced the lamp holder same thing.
anyone else run into this ?
The circuit board can have some light oxide, you can use some very fine sandpaper to clean the contact area.
One of my lights has a hole in the circuit board where the lamp holder contact meets. I think this is a common issue. I've tried to fill the hole with solder and wrap in foil. No brake light warning messages so far.
I also had an area where the board was bad and was able to fill with solder.
