Originally Posted by
oldroller
The headlight gaskets had bothered me enough, but at around 100 bucks for the pair I had other desires, like springs/struts.
So I decided on an interim repair.
<img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=604999"/>
The old... ugly and ineffective.
Removed the gaskets, and using a razor knife trimmed all the old rubber, to leave the bare plastic frame.
<img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=605000"/>
McMaster Carr part # 9141K119, L-shaped soft high-temp foam rubber, 5 feet, $13.35. Fitted the plastic to the headlight, and laid out the rubber to shape. I found that placing the short leg
of the 'L' under the plastic bottom edge gave a better fit. Tight to the headlight lens, snug to the hood. 3M weatherstrip adhesive holds the seal nicely.
<img src="https://www.bimmerforums.com/forum/attachment.php?attachmentid=605001"/>
It will do for now, until after the suspension revamp.
Cheers!
