SS US spec headers with SS mid pipes
SS euro reps with euro mid pipes
SS euro reps with 3 inch exhaust
Shorty headers with AA track pipe setup
Man, even at idle that sounds rowdy. I am excited for more videos.
Did you guys drill out the threads on the racelands, or are just jamming the bolt to keep it from loosening? My racelands that I just installed had threaded holes for the bolts.
95 cosmoschwartz M3/2/5 : 2012-1/1/2014 (worn rtab's and bald rear tires in the rain)
98 cosmoschwartz M3/4/5 : 2016-3/10/2017 (understeering SUV)
99 Estoril M3/2/5: 6/16/2017-current
Hrmmmi that's pretty aggressive . How bad is the drone ?
― George Orwell
The only thing we had to do actually was notch the motor mount arm.
Drone is medium. If it gets too annoying then we'll install these:
http://vibrantperformance.com/catalo...roducts_id=288
Well I decided to try my hand straightening out some of the dents (not on the tip
Before
After
I'm wondering if it will still be an issue?
Side shot .
― George Orwell
I think you should try it.
Or get a pipe expander from autozone and see id it would fix just the tip.
Worse case scenario you could just cut the flanges on and use band clamps to mate mid and exhaust since they should be similar diameter.
Or weld them together which isn't my favorite option but most new bmw exhaust are muffler straight to mid/header connection and the euro mid is easy to unbolt since it doesn't curve upwards
― George Orwell
If the flange has a matching bevel, which it seems to, I would put it in a vice loosely and pull the tube down with the flange resting on the top of the vise, the tube between the jaws, and use a ballpeen hammer to shape the dent back into the flange. If you go slow, you should be able to bang it to a nice tight fit. It shouldn't be an "exhausting" job.They should give you a discount for keeping it though.
Well sourcing a rear euro specish muffler has proven to be a bit difficult. Looks like I have 3 options.
1. Buy a scorpion euro m3 muffler, and install it with the euro ss race mid pipes.
2. Return mid pipes to turner/return headers to raceland, and go with cx racing full exhaust setup which uses shortie header with a y pipe into a 3inch exhaust.
3. Sell everything, and pretend this never happened.
They could so easily have bolted the ends to a piece of wood. Suggest that to the morons.
Here's what mine looked like. It was 'packaged' and shipped direct from SuperSprint. Plastic and bubble wrap only. Seems that after 8+ years, they still haven't learned.
Am still steamed, but appreciate that Eurosport Design (the retailer) took care of matters. Of the two replacement pieces, only one was boxed and it traveled from Europe to LA, then to Maui.
88M3 AW 43k miles Project FS
Just run something like what I have. Long tube headers going into a modified Bimmerworld S54 adapter pipe, into the Part B part of the AA track pipe, then the AA rear exhaust section. Obviously you can substitute whatever you want for the back section....
'03 911 Turbo 6MT fun car
'18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
'15 Cayenne Diesel Wife's DD
'17 KTM 690 "Adv" 2 wheeled Adventurer
Well I went ahead, ordered a scorpion evo m3 muffler. Let's see how it arrives from the U.K.
― George Orwell
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
The scorpoion exhaust landed undamaged. I'm waiting on a date for the install.
Walmart sells jack stands and socket sets.
― George Orwell
