Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 146
Thread: Best cams, street/track car
  1. #101
    Aug 2002
    Denver, CO
    '98 M3
    If I make mid to high 250's with the 264 cams I'd be pleased
    '03 911 Turbo 6MT fun car
    '18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
    '15 Cayenne Diesel Wife's DD
    '17 KTM 690 "Adv" 2 wheeled Adventurer
  2. #102
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    That is no problem. 10 years ago people were making 265 rwhp with 264/256 schricks.
  3. #103
    NY
    skateboard
    Correct European car made 264whp and 236wtq on an s50 with super sprint US spec headers, ss US spec mid pipes, SS or AA catback , off the shelf tune, and Evo sport under drive pulleys .
    It's doable.
    ― George Orwell
  4. #104
    Jul 2012
    Huntington Beach
    96 M3 Coupe
    Quote Originally Posted by DocWyte View Post
    Volloso just tuned a Schrick car to that range on a low reading dyno in 100º weather. I watched it happen lol. It's definitely within the range of possibility.
    Also, I'm fairly certain that you can use the springs from an M50 non vanos head. From what I recall they are dual springs and are significantly stiffer than any other valve springs in the M5x/S5x family. I went supertech because my cams are even more aggressive, but I was seriously considering them for a while.
    Check out this thread. https://www.bimmerforums.com/forum/s...-vs-M52-vs-S52
    Also, fun tip: Google image search for 'M50 non vanos valve spring' will turn up some of the photos from that thread that are no longer visible thanks to photobucket.
    @M3AMI
    96 BG/Magma Lux
    Mods. Lots of Mods.
  5. #105
    NY
    skateboard
    Quote Originally Posted by Foda420 View Post
    Yup I remember those old threads about the non-vanos springs . Good stuff
    ― George Orwell
  6. #106
    Aug 2002
    Denver, CO
    '98 M3
    Well, need to order a rebuilt vanos from VAC, so I'll just get those OEM+ valve springs from them too.
  7. #107
    NY
    skateboard
    Can't wait to see how everything works out for you man. I just ordered the final piece to my exhaust .
    ― George Orwell
  8. #108
    Aug 2002
    Denver, CO
    '98 M3
    Yeah, me too! Only thing I'm bummed about is that this didn't happen at the end of my season so I'd have the time to rip it apart myself.
  9. #109
    Aug 2002
    Denver, CO
    '98 M3
    OK, everything is ordered and on its way. Here's the run down
    Schrick 264/256 cams
    Epic Tuning for cams
    S54 Oil filter housing
    Euro E36 OEM oil lines and oil cooler
    Bimmerworld Vanos line banjo bolt
    Bimmerworld Oil filter housing thermostat bypass kit
    Bimmerworld Oil cooler mounting kit
    VAC rebuilt Vanos unit
    VAV OEM+ valve springs
    Camshaft and crankshaft sensors
    ARP head studs
    I'll let the shop order up all the gaskets, heater core hoses, etc. Head will go to the machine shop to get checked out. Sending the car to the shop next Friday.
  10. #110
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    You did not list a head gasket in the parts you have ordered. Did you check with your shop which brand head gasket they are going to use?
    [IMG][/IMG]
  11. #111
    NY
    skateboard
    ARP head studs
    Awesome .
    ― George Orwell
  12. #112
    Aug 2002
    Denver, CO
    '98 M3
    Going with a cometic head gasket. Shop will choose the thickness to give adequate piston/valve clearance but allow a bump up in compression ratio
  13. #113
    Jun 2005
    New England
    I would skip the cometic but my experience is with thicker ones for forced induction. I don't think the very minimal, probably unnoticeable extra power from a thinner gasket is worth the reduced reliability of the gasket and of moving the valves closer to pistons with stock reliefs particularly when using a higher lift cam. For a built NA motor, I might consider pistons that add some CR if I ran on 93 octane.
  14. #114
    Aug 2002
    Denver, CO
    '98 M3
    Hmm, good point. So which head gasket set should I get? OEM, Victor Reinz or Elring?
  15. #115
    Vancouver, BC Ca
    1993 325is
    My build has a Cometic headgasket and OEM headbolts, 11.5:1 compression forged pistons and is tuned/runs on 94 octane. I had no issues. But then my pistons have generous valve pockets.
  16. #116
    Indianapolis, IN
    951, LTW M3, GTI
    Elring.
  17. #117
    May 2003
    Irvine
    95 M3, 03 E55, 07 335I
    Go with OEM head gasket
    Old set up: 520RWHP & 500RWTQ @ 20PSI 1/4 mile as of 7/26/15 12.5 @ 125MPH - 19PSI
    New set up: Steedspeed Twinscroll, Wiseco Pistons 8.8:1 CR, K1 Rods, Blueprinted and Balanced, ARP Main Studs, o-ring block, GTR 12mm head studs, GT35R with 86mm HTA billet compressor wheel (GT3586RHTA) TwinScrol 1.06 exhaust housing, Nick G custom tuning, 6 Speed Transmission, UUC Twin Disc Clutch, UUC EVO III, UUC DSSR 109mm, EVO 6 Speed Driveshaft, HFS-6 W/M injection, Zeitronix data logger, 3" SS full exhaust, Rallyroad strut bar, X brace, Race coilovers.
  18. #118
    NY
    skateboard
    Elring is good. Reinz sucks
    ― George Orwell
  19. #119
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    Quote Originally Posted by GG///M3 View Post
    ^^^^^ This!!!!!! Elring most likely makes the OEM gasket for BMW. My M3 had 92k on it when I bought it, and at 102k the head gasket blew between 5 & 6. It was a Victor Reniz.
    [IMG][/IMG]
  20. #120
    Aug 2002
    Denver, CO
    '98 M3
    Interestingly enough, the Victor Reinz gasket set is quite a bit more expensive than the Elring one.
  21. #121
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Quote Originally Posted by jakermac View Post
    What brand of pistons?
  22. #122
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by JitteryJoe View Post
    Designed by Paul Burke from Imagineering and made by Wiseco.
  23. #123
    Nov 2010
    Whidbey Island, WA
    Nice. Thank you.
  24. #124
    Jul 2012
    Huntington Beach
    96 M3 Coupe
    And just like that the dream is dead...
    No idea what I'm doing yet. Maybe rolling it off a cliff. Any interest in a big cam, built head before I shove her over? LOL
    @M3AMI
    96 BG/Magma Lux
    Mods. Lots of Mods.
  25. #125
    NY
    skateboard
    Did you just install a window?
    ― George Orwell
  1. Subframe bushings. Once and for all. Which is best for a street/track car?
    By bennyfizzle in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-12-2016, 02:45 PM
  2. 2003 M3 Coupe - E46 Street/Track Car
    By varsity in forum BMW Cars For Sale / Wanted
    Last Post: 10-28-2005, 08:54 PM
  3. Replies: 4
    Last Post: 01-16-2005, 02:26 PM
  4. Solid Mounts on Street/Track car..... Yay or Nay?
    By Spencer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 12-19-2004, 05:35 PM
  5. Question for those with rollbars in street/track cars...
    By Saint in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-14-2003, 10:35 PM
