Results 1 to 25 of 26
Thread: DSC mulfunction
    Jan 2006
    BC Canada
    2000 BMW 323i, 2012 Merc
    Question DSC mulfunction
    I have 2000 BMW 323i and recently I have replaced the inner/outer tie rods.
    After the replacement I took the car to the mechanic shop for the wheel alignment.
    20 minutes after I drove away from the mechanic shop, all of the sadden 3 indicator lights came on my dashboard: 1) DSC; 2) ABS; 3) Brake.
    I phoned back to the mechanic and explained the situation. I asked him if this is something related to the wheel alignment activity. He responded that unlikely but invited me back to check the next day.
    The next day the indicator lights disappeared. Then a day after they came back On, but this time just DSC and ABS.
    I drove to mechanic shop, he looked if there are any sensors that could of gotten damaged. It seems that all 4 ABS wheel sensors were intact. He suggested leaving the car for a day with him, so he would connect his tester and drive around to see what is happening (I haven’t done that yet, can’t find a time when I don’t need a car for a day).
    As soon as drove away the lights disappeared.
    Then a day after all 3 indicator lights came back On.
    I ran my own Autel MaxiDiag Elite MD802 tester and found the following fault code:
    31 ; DSC: Wheel-speed sensor, rear left
    I deleted the code in order to see if this might be a glitch, but a day later all 3 lights again came back.
    I ran another test and this time I found 2 fault codes:
    A8 ; DSC: Voltage supply, sensor
    Since then all 3 indicator lights were spontaneously coming On and Off.
    On top of this there are instances when just the DSC indicator comes On for few seconds and at that moments the radio turns Off. As soon as DSC indicator disappears the radio turns back On.
    Has anyone here experienced the same situation?
    What can be done?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    I would suggest getting into the ABS/DSC ECU and watching the live data. In INPA there is a screen for you to watch the wheel speeds for each corner, and if one drops, you will see it.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jan 2006
    BC Canada
    I have Autel MaxiDiag Elite MD802 tester . Will this gadget do the same job?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I would bet one of the TINY wires on the left rear sensor pigtail is frayed - causing all of lights.
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    You have the trifecta. Welcome to the club. If you find a solution please post it here when you're done.
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    Remove all four wheel speed sensors from the car and check with a digital meter. When measuring in ohms you should get a reading in the hundreds or just below. Possibilty that if one of the sensors provides no reading that sensor should be replaced with a tested sensor, that should solve the issue.
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Are there four wheel sensors? I thought it was driver front and passenger rear. Maybe I'm confusing cars. Anyway, the same happened to me when doing the same job. Changed the sensor and it went away.
    Jul 2017
    Yes, please.
    Quote Originally Posted by TonyAngel View Post
    The E46 cars have 4 wheel speed sensors, one on each wheel hub area. You might be thinking of the brake pad sensors Tony. They are on the front left and right rear and attach to the brake pad.
    Jan 2006
    BC Canada
    The DSC indicator still comes On for couple seconds and at that moments the radio turns Off. As soon as DSC indicator disappears the radio turns back On.
    What can be done with this?
    dworthy's Avatar
    Nov 2010
    What have you done to get the car scanned for codes? With all the ECU's on that car, it is like fishing without a hook.
    Darin
    Current:
    Past:
    M-Flight Member
    Dec 2013
    Chicagoland area
    EXOTICS
    The codes indicate a wiring connection problem or failed left-rear sensor.Check, clean and swap wiring connections/rear sensors.
    Clear codes,rescan and observe if code transfers to right-rear,if so,replace sensor.
    Sep 2008
    Sandy, Oregon
    Has anyone solved this problem? If so, how?
    Apr 2013
    Jerzy
    2003 330i ZHP
    Just replace the left rear wheel sensor. You can try cleaning it but its just to replace it, clear the codes and see if anything comes back
    Sent from my VS988 using Tapatalk
    Jan 2006
    BC Canada
    I used Autel MaxiDiag Elite MD802 tester
    Dec 2013
    Chicagoland area
    EXOTICS
    Was a fault and fix ever found Yober?
    Jan 2006
    BC Canada
    Quote Originally Posted by MIKYZZ4 View Post
    very strange i was about to replace the sensor, but the for a whole month the indicators and codes disappeared. So i'm waiting to see if the indicators will come back, then I will replace the sensor.
    Dec 2013
    Chicagoland area
    EXOTICS
    Thank you for the update.
    Jan 2006
    BC Canada
    For almost 5 months the indicators were quite. Today all 3 indicators came back on. I will be getting to it tomorrow (if the rain would stop for awhile).
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    Yeah just because it is intermittent and in your case months of intermittency doesn't mean the sensor isn't bad. I see a lot of wiring issues over time as the protective barriers wear out.
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Sep 2008
    Sandy, Oregon
    It could be your ABS module. Mine was intermittent for months then on all the time. It was the module. Some can be rebuilt and some like the Ate module are considered not repairable. I put in a used module and had it coded. It's been working well since November.
    Jan 2006
    BC Canada
    Question
    the lights are off again .
    will wait for dry day to resolve this mystery.
    curry,wold my Autel MaxiDiag Elite MD802 tester be able to check the ABS module ?
    dworthy's Avatar
    Nov 2010
    If the lights were on, a code or codes will be stored in the ABS/DSC ECU. I don't know about the Autel if it can do what you need.
    Darin
    Current:
    Past:
    M-Flight Member
    Jan 2006
    BC Canada
    Autel MaxiDiag Elite MD802 tester shows one fault code:
    Dec 2013
    Chicagoland area
    EXOTICS
    Replace the sensor already,
    you've received confirmation from your tester, multiple times.
    Let's clear up this damn mystery!
    Sep 2008
    Sandy, Oregon
    I'm not sure I used a Schwaben to read my codes. It indicated a bad module. It wouldn't reset the codes. I had to go to a shop to do that.
    Quote Originally Posted by Yober View Post
  1. Estoril E36 M3, Sony DSC-F707 style.
    By CMT in forum BMW Rides & Events
    Last Post: 08-16-2002, 04:06 AM
  2. '02 M roadster, autocross, and DSC question (long)
    By notJob in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-22-2002, 11:47 AM
  3. HELP - DSC off but still some function??
    By mijgilbert in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-09-2002, 02:51 PM
  4. Dsc & Cbc
    By MAB Badgerbimmer in forum 2001 - 2006 M3 (E46)
    Last Post: 03-25-2002, 10:23 AM
  5. Brake,abs,and dsc lights came on
    By e46driver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-08-2001, 08:52 PM
