Results 1 to 7 of 7
Thread: Bottom end deaded... what would you do?
    Under a roof
    507whp 318i
    So it finally happened. Haven't really gotten into it yet to see exactly what failed but I'm getting serious blowby so something let go in the bottom end. The m52 lasted about 20,000miles or so of 20psi and ~450wtq so realistically I can chalk that up to a win. Right now my priorities are to the point where I really can't dump a ton of money into it so now I need to figure out what to do.
    I'm running a gt3582r with a spa t3 manifold on pump gas. It was making ~510whp/ 460wtq.
    So I guess it is ...
    1) buy another m52 and get right back where I was
    2) maybe see if the cylinder walls are salvable and keep it a 2.8 and throw some rods/ pistons at it
    3) bore it out a bit and do rods/ pistons
    What would you guys do if you were in this situation? HELP :p
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    For 500/450 buy another M52 for $700. It's the most bang for the buck. If you have more money buy an S52 and lower the boost. If you have even more money build a motor, preferably with an S52 crank and S52 bore pistons and aftermarket rods. Or if on a budget, M50 NV rods and aftermarket pistons. Plus cut ring gasket and ARPs.
    Under a roof
    507whp 318i
    Dang I thought you could get an m52 for easily under 500.
    Anything building the engine would be a minimum 2-3k in parts alone I'm sure ehhhh.
    Virginia
    97' m52 turbo
    Quote Originally Posted by bavdrftr318 View Post
    Where you running stock hg? Tune?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    I traded a 3.5" MAF for my m52. They can be had cheap.
    Aug 2012
    CT
    Twin turbo LS E36 M3
    I've gotten whole m52 swaps, with transmissions and harnesses for 400$
    But I'd put an ls in it
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Virginia
    97' m52 turbo
    Just get another motor swap it in. Do cutring/spacer. I could pull a motor where I live at the salvage yard for $250usd
  1. What would you do?
    By AutoCouture in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-29-2002, 06:24 PM
  2. what would you do?
    By sc323is in forum 1991 - 1999 (E36)
    Last Post: 06-05-2002, 12:14 PM
  3. What would you do?
    By TheBestCow in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-11-2002, 10:33 AM
  4. What would you do! Options...
    By ICWIG in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-09-2001, 06:55 PM
  5. what would you do?
    By vvtivanos in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-01-2001, 11:19 PM
