Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: Rod Bearing Failure M62B44
  1. #26
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    That looks good. The mystery continues...
    Pressure relief valve maybe?
  2. #27
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    No,that pump had been pumping debris. Sides of driven vane are scored, and pits on drive side of rotor.
    But the bearings probably failed first.
  3. #28
    Mar 2012
    Lansdale, Pa
    Some scores yeah, but enough to kill pressure?
  4. #29
    Dec 2005
    Davenport, IA
    1997 BMW 540i/6, others
    With the crap that was in the oil pan, some damage from pumped debris is expected. What I'm trying to identify at this point is the root cause of the bearing failure, not so much to see what parts may be good enough to reuse.
  5. #30
    Apr 2016
    Quote Originally Posted by qcdstick View Post
    Noted, and like i said, bearings probably failed first.
    The high miles engines (180-200k) that i have taken apart have all had rod bearings worn down to copper/ brass colored backings.
    I dont think that rod bearing failure is just an S62 thing.
  6. #31
    Sep 2015
    Mankato, MN
    1999 540i
    I'd look at the condition of the wear plates that sammich the pump gears. If there is wear there, there's an easy place for pressure to escape.
    (Where wolf? There wolf)
  7. #32
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I haven't read all of this post (at airport on my phone), you replaced the chain guides, right?
    Did you forget to put in the small oriface behind the fat green o-ring that feed oil to the tensioner, or is it the U guide. That would result in low oil pressure. The light only comes on below 7 PSI.
  8. #33
    Dec 2005
    Davenport, IA
    Are you talking about the swivel arm thing at the bottom bolt of the tensioner guide that presses into the block above the crank sort of behind the u guide? I had the guides on and off a few times figuring everything out, but I'm 99.9% sure I did.
  9. #34
    Dec 2005
    Davenport, IA
    Only semi-relevant to the topic at hand. Got my potential donor car home. 1997 540i 6 speed with 157,000 miles for $1,000. Only now I'm not quite sure I want to part it.
    The Bad:
    - It hasn't been driven other than re-parked around the PO's yard/driveway in over a year due to severe driveshaft shake and thumping over ~20mph or so. Got worse over time until he just stopped driving it, he thinks it's the guibo and I tend to agree.
    - Engine has a tick in the top end that the PO (who I've known a while so i trust) didn't recall from before. Most likely a collapsed lifter? I'm hoping it's just due to how long the car sat and some driving and fresh oil will fix it.
    - Mismatched hood, original one flipped up at 50mph destroying the hood
    - Cracked windshield from the aforementioned hood incident.
    - Front bumper is torn up pretty badly from getting hooked over a parking stop.
    - Interior is filthy up front with grease/dirt? not sure if it would clean up or not.
    - Car doesn't show it at a glance, but the rust monster is coming in a big way. Visible at the bottom edge of several panels, and the underside looks like one would expect for a car that lived in NY and the Midwest driven in the salt (ie, BAD).
    - Hood latch mechanism is still jacked up, currently I can't get it open although it was open when I looked at the car. Cable seems fine at least.
    The Good:
    - Body panels look pretty decent from a distance, some small dents and scratches.
    - Engine seems to run fine, aside from the tick in the one bank and a vacuum leak hiss when revving it.
    - It has the full Zionsville radiator, shroud, and Spahl 2 speed fan kit.
    - Headlights and taillights are upgraded with what appears to be OEM facelift units, or at the very least they are Hella brand.
    - Runs and drives, drove under its own power onto my trailer and then into my garage once home.
    - Has a trunk full of spare parts. Air filters, Oil Filters, valve cover gasket nut seals, window regulator, valve cover gasket, water pump o-rings, some misc gaskets related to the intake runner, those white door clips for the door panel that always break etc. based just off what I could recognize from the pile.
    I figure worst case, the engine is junk upon detailed inspection (unlikely) and I get a spare 6speed trans, spare zionsville setup, and facelift my headlights and tailights for my $1k investment I can't lose too badly. Could cannibalize the rest of the car for spares / part out as well before scrapping the rest.
    Not at all looking forward to tearing down the exhaust to get at the guibo after how much of a PITA my much less rusty car was to get free... But frankly, assuming the guibo repair is as expected, I'm considering just fixing it and leaving it as is because it will be a complete running car. I could use it as a winter beater for a few years, I already have wheels and snow tires or sell it for a profit. Of course, at that point I still need to track down a good engine for my car which puts me back at square 1 looking for a solid engine, or good candidate for a refresh (timing / rod bearings). Anyone know of any? I want to get MY beast back on the road too.
  10. #35
    Mar 2012
    Lansdale, Pa
    Run it some more with fresh oil and see if lifter tap clears. If so, just use this motor for your car along with the other items. Part and dump the rest. Car looks like it's beat.
  11. #36
    Dec 2005
    Davenport, IA
    Is this the orifice you are talking about? (dead center of picture, black part going between tensioner guide and U guide)
    If so, the good news is I didn't forget it. The bad news is, no closer to knowing what went wrong, if it was even something I did at all.
    On a related note. Dis-assembling the engine from the bottom up just feels wrong...
    Amazing how fast it goes though when A: You've just done all this crap recently, and more to the point B: It's out of the car and you can go to town popping bolts off with the impact.
    When I get my new engine, will be so nice to be able to prep everything accessible like this vs fighting the cramped engine bay! If I ever have to do a timing job in the car again, I'm taking the front clip off for sure. After seeing how easy it was, and how accessible it made everything, I feel like an idiot for not doing it the first time around.
  12. #37
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I didn't see this thread until just now. How's it coming? And did you ever find a likely cause for a loss of oil pressure other than a rod bearing being the first thing to go?
  13. #38
    Oct 2016
    San Leandro
    2008 535i, 2004 328i
    What's the first rod journal to get oil from the pump?
    I have a fresh set of heads for one of these engines if you find a short block.
  14. #39
    DeWitt, Michigan
    Quote Originally Posted by wagons ho View Post
    I've recently dismantled an old M60 and two M62s of unknown background other than they all seemed to be running engines. All three of them showed significant enough wear on the rod bearings (upper shell) that I agree with this assessment completely. I have to go back and look at the M60 bearings again, but I think they were in slightly better shape than the M62s.
    In these three engines the bearing wear had not caused problems yet, and the crank journals for the rods still looked good, but the rod bearings in the best of the three engines were down to the sixth layer in some places. The main bearings in the other M62 also had a few dodgy areas on them, and it seemed as if the crank wasn't perfectly straight. Very strange, and it seems unrelated to the rod bearings issue.
  15. #40
    Dec 2005
    Davenport, IA
    Quote Originally Posted by Yother View Post
    Thanks. Pretty sure I have a set of good heads as well. As of today, still looking for a block.
    Quote Originally Posted by tptrsn View Post
    Never determined the cause for sure.
  16. #41
    Dec 2005
    Davenport, IA
    Finally got around to tearing into the free engine I got. Saw it outside my local mechanic's shop, destined for the scrapyard, complete with automatic transmission. Story I got was that the guy brought it in because he hired a guy to do his timing guides, and the guy screwed it up and now he just wants to replace the entire engine, which is what he was having this shop do.
    What actually appears to have happened, is the owner ran the engine clear through the guides going bad, until it eventually skipped time and cooked the engine. Just pulling the valve cover, everything inside was coating with aluminum shavings. The deeper the place for oil to sit, the deeper the shavings are, so it was run quite a while metal on metal. Guessing the guy made up the other mechanic story because it sounded better than admitting "Yeah, my engine was making terrible noises for a long time, but I kept driving it and now it doesn't work at all".
    May continue tearing it down and inspect the lower end bearings just for fun. What are the odds that the filtration was good enough to protect the bottom end when run with metal shavings for this long? Oil pump is probably worse off with only the pickup screen to protect it...
    The adventure continues!
  17. #42
    DeWitt, Michigan
    I have a good block. I've been dragging my feet on putting it on eBay...
  18. #43
    Jun 2017
    Varna
    e39
    M62 need crank shaft bearins change, main and rod at about 300 000km, if you check the bearings of the "new" engine you will see..
  19. #44
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    Just stumbled upon this thread. The oil pump was most likely the culprit, man, don't beat yourself up. I dodged a catastrophic engine failure because I just felt something was off and pulled everything to learn the pump was bad. Your impeller looks very scratched and that's not an issue per se, you need to inspect the casting mating surfaces which I believe are going to be crudely botchered if the steel impeller looks like that, and the 2 pressure valves, the low and high relieve pistons (one's nickel plated pot metal, the other it's just a piece of plastic with some o-ring)
    Here's some pictures from my oil pump
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
  1. E36 S54 (w/ rod bearing failure damage) - 2002
    By mjbens01 in forum Engines, Performance Parts & Software
    Last Post: 04-08-2012, 09:02 PM
  2. Rod bearing failure on S54 Coupes?
    By dave is cool in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-17-2011, 09:04 AM
  3. Rod bearing failures on 2004+ M3's?
    By GoSlow2GoFast in forum 2001 - 2006 M3 (E46)
    Last Post: 11-30-2010, 05:13 PM
  4. Replies: 4
    Last Post: 05-07-2010, 01:27 PM
  5. connecting rod bearing failure
    By iTz BMWz FiNeSt in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-19-2007, 06:46 PM
