It seems that the Rally Road Oil Cap is well accepted to be effective but I wanted to see what cooler and hose kit would be least expensive and still work well. Do those small fans help?
I dont have any engine mods other than a flash and cat-delete.
Any links would be appreciated.
I will be running gauges for monitoring oil temp/pressure and water temp.
I just put a cooler in my E36, and looked at the top-of-the-line expensive plate coolers. As far as I can tell, the Derale stacked plate coolers are good enough, but a lot cheaper.
But it's not plug n play, if you need that. You'll have to figure out where and how to mount it.
Oil pressure drop is the concern many people have putting these in track cars. I looked at the cap you mentioned and it has -10 AN fittings which is good. For my install, I used -10 fittings and 5/8 ID hose throughout, and the 19 row medium width plate cooler. No pressure drop worth mentioning. I don't know if everybody NEEDS that much flow capacity to control pressure drop adequately. I just throw it out because I know now, it's one way to get it done.
If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
I made my own kit. Rally road cap -8an, Setrab 619, nylon braided hose, 180F thermostat. Fabricated brackets using aluminum flat bar from home depot to attach the oil cooler to the radiator support and fan shroud, used rubber isolating bushings to dampen vibration and shock to the oil cooler.
Only thing i would change on my setup would be to get a 200F thermostat so the car warms up faster during the cooler seasons. On track i was a steady 220-230F during a 50 min session, 95F ambient temp.
Was around $500 for everything.
I'm probably going to go all OEM. So S54 OFH, Euro E36/S54 MZ3 cooler lines, oil cooler, brackets etc. Total bolt on.
'03 911 Turbo 6MT fun car
'18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
'15 Cayenne Diesel Wife's DD
'17 KTM 690 "Adv" 2 wheeled Adventurer
Yeah, my CSF Racing radiator has the same brackets on it for the euro oil cooler. I'm probably going to buy the lines and cooler new, they're not that expensive.
Don't forget that with the Euro oil cooler you'll also need to revisit the US car's air shroud setup, which doesn't provide for airflow below the radiator. The Euro E36 M3 used an entirely different shroud:
Since I use the Euro shroud but a homebrew oil cooler (see above pic) I had to do the reverse, blocking off the bypass under the radiator. My oil cooler is mounted on a hardware store square section aluminum extrusion fastened to the bumper supports with U-bolts.
There are also anti-vibration stays at the bottom of the cooler, cut and bent from hardware store aluminum bar, that attach to the aux fan shroud.
Complete installation.
Oil lines are AN-10, fed from the S54-type oil filer housing, which incorporates a thermostat. (The alternator cooling duct, which needs to be trimmed for hose clearance, is removed for this photo.)
This setup has been in use since 2007 and works perfectly.
Neil
I don't have the stock undertray. Running a Motion Motorsport splitter/undertray, and a custom duct piece to the radiator.
So will need to adjust that custom piece a bit to accommodate the cooler....
NeilM, nice work there
Thanks. The only thing I'd do differently today would be to use lightweight Aramid covered hose, which wasn't available back then. Not for the weight savings, but because it's much more flexible than the stainless steel braid stuff. Every now and again I think about updating it, but why mess with something that works?
Neil
I run the Bimmerworld C&R Radiator and Oil Cooler on my S54 swapped E36. It works well, even with AC still installed, with a caveat that I had to do some ducting to the oil cooler. The AC condenser blocks a good portion of the oil cooler from getting any air, and the stock US shrouds don't do much to make air go into the cooler, so I fabbed up some quick and dirty ducts to direct as much air as possible to the oil cooler (without pulling AC). I'm using the S54 OFH and the Z3M oil cooler lines.
"Fear disturbs your concentration" -Sabine Schmit
1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
I didn't buy it recently, have had it awhile
Keep in mind with any kind of heat exchanger such as radiator, oil cooler, intercooler etc. that you are throwing away efficiency if it is not ducted properly. Given the chance, air will flow around it rather than through it taking the path of least resistance. If there isn't a pressure differential from one side to the other you won't get air flow through it and all the money's spent on fancy hoses, fittings and are a waist (comparatively speaking).
Duct the crap out of it and make sure you have an under tray. The euro M3s under tray extended aft to the guibo.
I got a used one off a euro, along with the aluminum doors. A buddy of mine ordered a brand new one. They are around.
Plus 1 on the ducting. My car is straight track now but the the path I took to get there: Remove pusher fan, aluminum radiator, Spal 16 inch wired to dash switch, Bimmerworld adapter for the housing (sends all oil through the cooler), AN fittings with press lock hose (soak in solvent to expand and push on) aftermarket oil cooler mounted to the brace in front of the rad, kidneys are blocked off. Mechanical oil temp measured at the pan
ME:"I want to make my car faster and lighter"
THEM:" Get out and let someone else drive"
I don't run any oil cooler on my race car. Oil temps on track never go above 220. In july they were holding steady at 208 for a 40 minute race at VIR. Oil cooler on an s50/52 is just another failure point for leaks. Not needed. If oil temps are getting above 270 on this motor you have other issues like blown head gasket or non existent rod bearings.
Oil temps are very dependent on environment. I certainly never saw 208 here in Denver. Combo of thin air and high heat does me in. That being said, I never saw close to 270 either.
