Page 3 of 3 FirstFirst 123
Results 51 to 68 of 68
Thread: Need Thoughts/Feedback on Buying This Car...
  1. #51
    Bellevue, WA
    335d, 328xd (had 330xi)
    Quote Originally Posted by BeastonMW View Post
    As promised, here are the pics after a thorough washing and waxing. I didn't get to the interior today. That will be this coming week. Hope everyone enjoys the exterior!!
    Looks like you got "hit" by the new Photo-bucket policy. You need to pay $400 to enable 3rd-party access.
  2. #52
    Bloomsburg
    '04 Rav4, '84 300SD
    Quote Originally Posted by floydr View Post
    Ugh, ridiculous. I'll host on another site and fix shortly. Thanks for letting me know!
  3. #53
    Bloomsburg
    '04 Rav4, '84 300SD
  4. #54
    Bellevue, WA
    Beautiful car, exterior very clean. Interior good from the one pic.
  5. #55
    Bloomsburg
    '04 Rav4, '84 300SD
    Thanks! Only problem with interior is sagging a pillars and rear view mirror is busted and stuck on night mode.
    Anyone have one for sale??
  6. #56
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Man, that car is in good shape. I don't know that it was worth $5k, but assuming everything is reasonably right under the skin, I really don't think you got ripped off.
  7. #57
    Bloomsburg
    '04 Rav4, '84 300SD
    Quote Originally Posted by TonyAngel View Post
    $4895 to be exact
  8. #58
    Bloomsburg
    '04 Rav4, '84 300SD
    So I just spent the last hour researching BMW alignments and I'm torn between the shop using weights vs not.
    What is everyone's thoughts on this? Where do you guys get your car aligned and do they use weights?
  9. #59
    Feb 2017
    Metairie, LA
    Ok, OCD much? LOL.
    Before you do that, did you confirm front control arm bushings, all joints?
  10. #60
    Bloomsburg
    '04 Rav4, '84 300SD
    Ok, OCD much? LOL.
    I did. All looks to be sound. But I rotated the tires 2 days ago and did them cross direction. Now I pull to the right slightly. And yes, OCD
  11. #61
    Feb 2017
    Metairie, LA
    Wait, are you saying that you pulled to the left before you did the rotation or are you saying that the pulling to the right occurred immediately after rotating the tires. You sure it isn't a brake sticking?
  12. #62
    Bloomsburg
    '04 Rav4, '84 300SD
    Immediately after rotating pulled to right. Prior to that it was OK.
  13. #63
    Dec 2013
    Chicagoland area
    EXOTICS
    Possibility that they are a staggered set.
    Check wheel & tire specs.
  14. #64
    Bloomsburg
    '04 Rav4, '84 300SD
    Quote Originally Posted by MIKYZZ4 View Post
    Tires are Continental's and are all the same size. I went through the owners manual and couldn't find anything about tire rotation. Tire pressure was all good in all 4 tires as well. My only theory is the rear tires wore slightly differently than the front from not being rotated previously and are causing the pull to the right when I moved those to the front. Everything checks out now and it drives in a straight line.
    I am considering purchasing the Firestone lifetime warranty as I did with my VW, but I'm sure Firestone doesn't use weights as suggested by BMW.
  15. #65
    Dec 2013
    Chicagoland area
    EXOTICS
    Doesn't hurt to ask if you can sit in the drivers seat during alignment,
    you can't get more accurate than that!
  16. #66
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Interesting...I too bought recently my first BMW, an 03..325XI wagon...for the exact $..4995...in Waltham Massachusetts in Mid March 2017.
    I did not put this car on the road until a week and a half ago, still I have to visit the DMV for perm plates...tomorrow!
    Things I learned before purchase....garage kept: true...serviced by BMW: not....
    116.3 K miles...two original Michelins still on car..no rust, no ultraviolet damage...yes.
    Original brake fluid, transmission fluid, power steering fluid....probably...change anyway!
    Also, the valve cover gasket shows a cheap silicone repair. I pulled the two pans again off to inspect a 500 mile drive. I have a minimum of oil leakage and with no sign of 90 weight or ATF appearant...
    This car looks, drives, sounds, as a new car...but it will now after 14 years still require all fluid changes....and hopefully the transmission was not abused and can except a full fluid change without future problems as a result of this fluid change.....Always a gamble buying used...
  17. #67
    Bloomsburg
    '04 Rav4, '84 300SD
    Quote Originally Posted by Eaglesail View Post
    Congrats on the purchase!!! I must say, from the carfax, the car I bought was BMW dealer maintained. All fluids (coolant, atf, brake) look to be quite fresh. Under the motor to the trans she's bone dry. Have had the car since Saturday morning and put about 400 miles on her. I check the oil daily and shes thus far dead on the full mark. Interior has also been spared from UV damage EXCEPT the rear view mirror is all mucked up from the internal liquid breaking. Hoping to find one at my local u-pull it yard this week. Other than that, 2 new a-pillars and she's perfect.
    Next week I plan on flushing the power steering fluid and dumping the gear oil for some Redline MTL and putting some Amsoil 75 90 in the rear diff. I am curious to see the quality of those fluids once drained. If they are like the rest of the car, I believe they will be somewhat fresh. As far as brake fluid, I plan on doing pads and rotors in about 3-4K miles. The current rotors are not shot but definitely worn as well as the pads. They have some life left but I am picky about brakes. The current brakes on it now are semi-metallic and squeak at low speeds. ANNOYING! I plan on going Bosch Blue ceramic pads, all the way around. Great quiet braking and significantly less brake dust on the rims.
    The one pressing thing I need to do is adjust the e-brake. She doesn't hold the car even pulled all the way up.
  18. #68
    Bloomsburg
    '04 Rav4, '84 300SD
    Question for someone. Is the rubber sleeve that sits on over the fuel filter, reusable?
  1. Halp, need some advice on whether this car is a good buy.
    By E30Enthusiast in forum 1983 - 1991 (E30)
    Last Post: 12-27-2014, 08:12 PM
  2. Need your opinion on buying this car
    By Tru Ston3r in forum 1996 - 2003 (E39)
    Last Post: 12-18-2014, 09:42 PM
  3. Please advise on buying this car
    By ig77 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-08-2011, 05:16 PM
  4. Thought on buying this car?
    By Appleman6161 in forum 1983 - 1991 (E30)
    Last Post: 08-31-2011, 04:39 PM
  5. new to forum need some input on buying this car
    By bryans 86 in forum 1983 - 1991 (E30)
    Last Post: 09-13-2007, 10:41 PM
