Results 1 to 14 of 14
Thread: The elusive terminal R
    San Jose, CA
    1997 BMW 540i 6 speed
    I have tried to determine the source of this signal. It energizes one of the unloader relays, K3. Where does it originate?
    Lawrenceville, GA
    4 BMWs.
    What is Terminal R?
    San Jose, CA
    Turns out it energizes some relays in iggy switch position 1. Powers the radio, et al.
    Lawrenceville, GA
    4 BMWs.
    Ah, thanks for the clarity.
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Actually, Terminal 15 is accessory (aka position 1 on ignition switch), while Terminal R is "running" (aka position 2 on ignition switch). There is a difference as things like headlights aren't powered in position 1, but they are in position 2. There should be plenty of locations to find Terminal R, but are you needing it to be powered in ACC mode as well as running, or just running?
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Just for clarification (I'm open for correction ) ...my understanding has been the ignition positions & their "terminal" references are:
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by Qsilver7 View Post
    This is your own post on bimmerboard saying the opposite for R and 15: http://www.bimmerboard.com/forums/posts/860334
    -Paul
    (northeast) Indiana
    Quote Originally Posted by blackknight530i View Post
    (LOL) Yup...that's from 2011 when I also still used the confusing terminology "run" and "accessory"...which are still confusing to me when I read those terms...for some reason I find them hard to place as to which one of those terms applies to when only some of the modules are initiated (KL R or terminal R) and when all the modules are powered (KL 15 or terminal 15).
    I no longer use "run" and "accessory"...and will usually ask for clarification when someone posts using those terms and refer to them in trying to solve their issue. I guess you can say...my thinking on KL R & KL 15 has "evolved" after tearing into more BMW docs & PDFs.
    I just noticed that I also inserted the wrong link to the terminal 15 (KL 15) Pin out...here's the correct one: https://www.newtis.info/tisv2/a/en/e...nal-15/ZLzcuYy
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    The "unloader relay" on these cars is oddly titled. I think it might be a legacy 'error' in a way?
    Many cars, esp older ones, would cut out all but a small subset of the accessories during cranking. On other cars I've owned, that'd be exactly what was called an 'unloader' circuit or relay. Basically almost everything would come on in positions 1 and/or 2, but then in pos 3 (cranking) some stuff would get temporarily cut back out again to lessen electrical load etc.
    On the E39, as far as I can tell the K3 "unloader" is just on all the time in pos 1/2/3 because it's driven by term 2 of the ig switch via F43. Took a bit to hunt this down and unravel it but...
    http://www.bmw-planet.net/diagrams/r...000009945.svgz
    http://www.bmw-planet.net/diagrams/r...000017044.svgz
    One the reason 'unloading' doesn't happen as much is likely that with all the computerized modules in the car, you can't really have those things booting up, then rebooting again when you hit the starter, and expect them to all communication seamlessly and maintain functions properly.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    San Jose, CA
    Seems like the radio/CD and lighting are turned off while cranking.
    I'm sure you're correct re the various modules. These cars are so finicky. There may not have been any systems engineers afoot when this electrical system was being designed.
    Apr 2013
    Melbourne, Vic, Australia
    2006 BMW X5 3.0d
    So is KL 15 accessory position 1,
    and KL R position 2 (run) ???
    Jun 2020
    new zealand
    e90
    Quote Originally Posted by deepblonde View Post
    out of bmw manual
    Terminals
    B+ Battery￿Positive
    B- Battery￿Negative
    KL Standardized￿Abbreviation￿for￿Clamp￿or￿Number
    Terminal
    KL_0 Ignition￿Switch Off
    KL_R Voltage￿Ignition￿Switch￿in￿ACC,￿Run￿Start.￿Hot￿in￿ ACC/Run/Start
    KL_15 Voltage￿Ignition￿Switch￿in￿Run￿and￿Start.￿Hot￿(12V )￿in￿Run/Start.
    KL_15N F01/F02.￿Voltage￿Ignition￿Switch￿in￿Run￿and￿Start.￿Hot ￿(12V)￿in￿Run/Start
    KL_15U/15i Voltage￿Ignition￿Switch￿in￿Run.￿Hot￿(12V)￿in￿Run.
    KL_30 12V￿at￿All￿Times￿(Relay￿Work￿Power).￿Hot￿(12V)￿All ￿Times.
    KL_30g 12V￿with￿time￿disconnection.
    KL_30B F01/F02.￿12V￿with￿time￿disconnection.
    KL_30g-f 12V￿with￿fault￿disconnection.
    KL_30F F01/F02.￿12V￿with￿fault￿disconnection.
    KL_30H Starter￿Signal
    KL_31 Ground
    KL_50 Voltage￿Ignition￿switch￿in￿Start.￿Hot￿(12V)￿in￿Sta rt
    KL_58 Interior￿Lighting￿Dimmer￿Signal
    KL_61 Ground￿with￿Alternator￿Output,￿12V￿with￿KL_15
    85 Relay￿Coil￿Ground￿(Signal)￿control￿side.
    86 Relay￿Coil￿B+￿control￿side.
    87 Relay￿Output￿Work￿Side.
    87a Relay￿Output￿Work￿Side￿At￿Rest
    (northeast) Indiana
    Although this is a late reply...why is this even being questioned two year after it’s been answered and the correction discussed...along with links to the TIS that give descriptions etc?
    • KL R = ignition position 1 (some modules are powered)
    • KL 15 = ignition position 2 (all modules are powered)
    ...and again...I still don’t quite get what “run” and “accessory” means...so I still don’t use them because they are confusing and seem to mean different things to different people. It’s kind of like using “driver’s side” and “passenger side” when its not clear if the vehicle is LHD or RHD. The answer depends on data that isn’t known.
    Jul 2020
    Texas
    2009 x5 35d
    Hey QSilver 7 - only slightly off topic, but i can’t switch off terminals 15 and R for a forced regeneration request. Do you know if i need to be waiting 16 mins for those to go to sleep after removing the CA key from slot before i try to proceed? 2009 x5 35d (using Foxwell nt510 elite).
  1. The elusive fuel filter...
    By Jamaican71 in forum E39 Common Problems and DIY Fixes
    Last Post: 02-22-2017, 05:08 PM
  2. I think I found the elusive pic of Johnny
    By 12:03 in forum Southwestern - US
    Last Post: 12-07-2004, 07:27 PM
  3. In search of the elusive coilover
    By Hobbs64 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-29-2004, 10:31 PM
  4. Alarm Install - Found the Elusive P/G/Y Hood wire ... now what?
    By avusblue in forum 1992 - 1999 M3 (E36)
    Last Post: 06-30-2003, 11:32 PM
