Hi I am parting a rusted out 535i 89 e34 with 195,000 miles. The car does run and shifts nicely. It also has a 3.46 LSD
3.46 LSD 225 plus shipping
Manual swap 725 for complete swap. plus shipping
Tranny, brace, fly wheel, clutch, pressure plate, slave, driver shaft, master, pedals, reverse wiring.
Exterior
Hood 70
Door Cards.
All bad
Door latches 8 each.
Drivers Seat for parts
Passenger seat for parts
Tan glove box 20
Blue glove box 20
Dove grey glove box 20
Black glove box with wood 35
Black kick panel 20
Dove Grey center consul 30
Blue Center Consul
black ebrake consul 25
Dove Grey ebrake consul 25
Dark grey consul 25
Tan consul 25
Drivers kick in different colors panel 25
Instrument cluster (have 2)75
OBC 35 All the pixels are good
with airbag with airbag 35
steering column 35
wiper stalk 15
turn signal 15
Cruise stalk 15
Head lights switch 15
Hazard light 10
hvac control 25 (I have from 89-90 and late 90-95
window switches 6
large window switch next to seats 15
Fog light switch 10
sun roof switch 8
interior both 12
map lights 8 each have light and dark grey
Face plate for Hvac controls 20
Sun visors 20
seat belts and receptacles 5 each
vents (from 5 to 15)
rear ash trays 5 each
mirror 15
Sunroof motor 20
Other sunroof stuff e-mail me.
Carpet grey or tan in good condition 80 will ship by grey hound or UPS (have 2)
Speakers ask.
exterior
Wheels
style 5 175 have 5
Style 42 16 inch 150
15 inch bottle caps 100
Door stuff
Doors 75
window motors 35 each
actuators 15 each (have booth old and new style)
door handles 5 each
door handle trim 5 each
latching mechanism for drivers door 75 all others 20
window 25 each
door trim 15 each
newer style kind of mirrors in Dark Green 20 each
older kind in black and light blue and silver and red 15 each
grills 15 each
Center grill not missing chrome 20
Head light 35 each
Turn signals 5
wipers 8 each
Tail lights 15 each part
sunroof panel 30
front bumper 150
Rear bumper 100
Engine Compartment and other things
Engine cover for m50 35
wire harness 80
ECU 50
ABS control 30
LKM 25
GM 30
CCM 25
AC compressor 35 for m50
Alternator for M50 35
maf 40
Throttle body 25
Intake manifold 75 (for m50)
exhaust manifolds 25
Air box for 30 for m50
Air box 30 for m30
Air box for m20 20
Anti-lock brakes box 30
wiper motor 20
wiper tranny 35
washer fluid reserve 15
washer pump 10
Haft Shafts 30
brakes 30 each
rotors 20 for front and rear
Steering box 85
Radiator 35
Power steering pump 35
Blower motor 35
Trunk
Fuel pump 50
gas tank 60 (must pick up)
Carpet pieces (ask)
Hi if you did not see a part listed it is most likely because I forgot to list it. So please ask.
Andy
Air bag wheel or no ? If no I may be interest in the cruise stalk. Also trunk net ? Clips for trunk net ?
Do you have the hood insulation pad? If so, how is its condition? Thanks.
AC Compressor for the early M30? Does it whine?
bump
Andy
Console Windows switch block if all operable and rear door actuator for my 89
shipped 93446 paso Robles
Andy
bump
Andy
Do you have the front brake shields/protection plates available?
Is it a grey back cluster?
Bump
Andy
Do you have the seat belt receptacle? Shoot me a pm.
bump
Sndy
Is the door rust repairable?
Sent from my SM-G955U using Tapatalk
Which door?
Andy
Bump
Andy
Hi Andy. I'm interested in a couple parts if they will fit my 1991 535i A/T (manufacture date 11/90). I'm looking for the engine wiring harness as well as the wiring that connects from the wiring harness to the fuse box. Do you know how I can determine if yours has the same wiring? Thanks!
Hey Andy,
re: hvac control 25
I'll take the 89-90 HVAC control, don't need the radio/OBC bezel, but need the complete lower control unit if it's not broken/damaged.
e30 84 340i m6x powered.
e34 89 535i 5speed - current DD
e24 89 635csi - maybe a DD?
e34 93 525i (m50tu) - gone
e39 540i 6spd m-sport - gone
e53 x5 4.4l - gone
e30 89 325i (m20) - gone
bump
Andy
Can I get a part number off the ECU/DME? Interested in that, the left tail light, and possibly a few interior bits.
bump
Andy
Headlight surroundings and distributor cover?
