Results 1 to 12 of 12
Thread: Lifting Inner Front and Rear Wheels at Autocross
    Dec 2015
    Redford, MI
    1993 BMW 325i Coupe
    Hello,
    I have been a member for some time, but this is my first post. I really appreciate all of the information I have been able to gather that you guys have provided! So thanks a lot for that.
    I have been doing quite a bit of searching and am really having trouble finding the answer to my problem. First of all the car: It is an e36 with the s50 in it, stripped down, no cage, and weighs in at 2236lbs. I am running 285/30/18 Hoosier A7 all around. Currently I have 700lb springs in the front and 900lb in the back, TC kline shocks front and back, UUC front sway bar on the stiffest setting and currently no swaybar in the rear.
    I have tried a variety of spring/sway bar combinations in the rear including none, stock e36 325i sway bar, and the UUC rear on the soft setting. For springs I have tried 750 in the back and 900 in the back.
    All of the aforementioned combination cause the front wheel to lift off (which I am generally ok with). The problem is that the rear also lightens and If I try to put some power down mid corner it just spins the inner rear. The car has an 3.38 LSD from an automatic M3.
    The car is generally well balanced it doesn't understeer or oversteer too much. I feel like the suspension setup is close to where I want it to be, but I am just trying to work out this bad behavior without buying another set of springs or sway bars on a "gut feeling"
    I appreciate any help you guys can provide. Thanks.
    Canada B.C.
    1995 bmw 325is S50B30
    What trailing arm bushings do you have?
    1995 325is 5 speed S50B30
    I like the colour, No Bias
    Because Racecar
    -Did you hear that?
    Dec 2015
    Redford, MI
    1993 BMW 325i Coupe
    I have spherical bushings on the trailing arms and the control arms. I moved the suspension up and down without the springs or swaybar attached to check for binding, and I didn't feel any.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by Caius View Post
    If you have that issue in the rear, it would seem like you eigther don't have enough roll stiffness for that combo of wheel/tire grip, or not sufficient droop travel in your shocks. No expert but my humble opinion for what it's worth.
    Aug 2012
    Central, MD
    1995 M3
    285 Hoosier A7s, an (old?) OEM LSD, and autocross (aka some tight turns). And you're getting inside tire spin.
    The fix *may* be a new (and modified) LSD?
    Mar 2011
    Neverland
    E34 525i
    Thats a pretty aggressive setup. I agree on rebuilding the LSD unit and maybe throwing an extra disk in there for the 40% lock, and if possible find a way of dropping the front roll center of the car (not sure if possible on e36) to help it keep the front planted.
    Springfield, IL
    Quote Originally Posted by Hofmeister View Post
    Not sure there is any solution for the front given the camber gain with a smaller front bar and the roll center issues when dropping below parallel. Lifting inside front wheel is the nature of these beasts.... Mine clears atleast 3 inches...
    Vancouver, BC Ca
    1993 325is
    I too have this exact problem. I'm 800fr, 900rr, GC small front bar, 275/35-17 (never ran A7s, only 6s) on 10.5" wheels. I'm convinced that I need a bigger front bar. I'm going to try the medium GC front bar. And I have about 28mm of front roll center correction - SLR Speed mini kit.
    Have you checked the clearance between the rear upper control arm and the chassis? Is there any chance you're getting contact between the spring centering nubs on the frame/control arm? I've cut mine down to 1/2 their height on both the arm and the chassis.
    I have made a bunch of changes to try and correct some of this, and then I took a sabbatical from autocross for the last 3 years. I am almost certain that it's the lack of front roll stiffness. I'm a little heavier at just under 2,400 lbs (Street Mod legal) but I'm pushing 270/240 at the wheels with a built motor.
    Springfield, IL
    Quote Originally Posted by jakermac View Post
    Flares or bodywork? Just curious....
    Vancouver, BC Ca
    1993 325is
    Hard Motorsports flares shimmed out for more clearance. Extensive mods/body work under the flares.
    285/30-18 on 10.5:
    275 Hoosiers:
    Jan 2012
    Southern NJ
    97 M3 Coupe, 05 LGT
    I've been fighting the same issues all season. The inside rear won't get the power down out of corners. The car feels pretty good otherwise. 650/800 springs on JRZ RS D/A. Eibach F-ARB. 255/40/17 RE71R. I tested LSD breakaway torque at 39ft-lbs. I have not been able to locate a definitive answer on what breakaway torque for the OEM 188 diff should be.
    My car is not corner balanced though, but I have an appointment finally on the 26th. I've been putting it off for 2 years so i can get the car down in weight first and have to miss a day of work to get to the shop (far). I'm hoping after I'll be able to put down the power much earlier.
    Dec 2015
    Redford, MI
    1993 BMW 325i Coupe
    Thanks guys, I appreciate all of the input. Although I had thought of the diff being part of the problem, I was really hoping to point fingers at something less expensive... lol But I guess such is the nature of the beast.
    In a recent update, I have done two more events since I posted this, and I found a setup that shows some improvement. I dropped the car all around about another 3/4". Went with the 900lb rear springs and a UUC rear roll ball on the soft setting.. This still allows the inner rear to spin, but seemingly not as much... Now the problem is that off the start I spin the tires all the way through 1st and partway through second gear. Its really hard to get it to hook up on launch due to all of the stiffness back there.
  1. E46 Brand New front and rear wheel bearings e46
    By e36M3to996 in forum Suspensions, Springs & Shocks
    Last Post: 11-05-2012, 08:25 AM
  2. E46 M3 18" Front and rear Wheel
    By SKYWLKR in forum Wheels and Tires
    Last Post: 10-01-2009, 11:17 PM
  3. OK to place different tires brands on front and rear wheel?
    By Orcrone in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 08-16-2009, 11:06 AM
  4. Replies: 1
    Last Post: 07-04-2007, 06:22 PM
  5. How to identify front and rear wheels?
    By bitchincamaro in forum 1992 - 1999 M3 (E36)
    Last Post: 07-26-2005, 05:37 PM
