Results 1 to 9 of 9
Thread: ABS problem... A little different from the rest I've seen
    Jul 2017
    Oak Lawn, IL
    07 Chevy Monte Carlo SS
    Post ABS problem... A little different from the rest I've seen
    Hey guys, I'm brand new to the forums and BMW!
    About 6 months ago I finally purchased a 2000 5 series. Looks good runs great, but has a strange problem..
    I had the 3 ABS lights that I've seen a lot of BMW owners posting about (ABS, DSC and Brake). Those 3 lights popped up on mine but everything else (speedometer, fuel gauge) worked just fine. I bought the BMW scan tool and the adapter for the port under the hood. I scanned the ABS and it said front right sensor was bad. I changed it with an OEM part, no changes. Last week the dash lights came on, but the time it was just 2 of them, DSC and ABS.. No brake light. Now the speedometer doesn't work and the fuel gauge if "iffy" when it's low. Also, ever since the brake light stopped coming on, I am unable to scan the ABS system under the hood.
    Does this still sound like the module is bad?
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Sounds like a bad module to me
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
    Jul 2017
    Oak Lawn, IL
    Thanks for the response! I'm probably going to send it to be rebuilt, as long as it's not too far gone. I found someone on eBay that does it for $95.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Agreed sounds like bad module. Gas tank is separate issue but all the other stuff points the same direction.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Jan 2013
    2003 BMW 530i Sport
    I would definitely check the rear left speed sensor. That's the one that controls the speedo. A decent chance that it's the problem. Go with BBA on eBay if you want to repair the module
    Jul 2017
    Oak Lawn, IL
    Thanks for the reply. BBA is the one is actually the one I was planning going with.
    Could the rear left sensor be bad even if it's not throwing a code?
    Jul 2017
    Oak Lawn, IL
    I replaced the left rear sensor with no results. I'm sending the abs module out as soon as he sends me the shipping label.
    Jul 2017
    Oak Lawn, IL
    BBA fixed the module and had it back to Chicago in 3 days. Problem solved!!
    Mar 2010
    Nice.
    2003 M3CicM6 TiAg
    Former:
  1. Why is mine different from the rest...
    By caleb325 in forum 1983 - 1991 (E30)
    Last Post: 10-21-2011, 02:58 PM
  2. idle problems this a little different from the rest ?
    By 1craigus1 in forum 1991 - 1999 (E36)
    Last Post: 05-05-2009, 01:43 PM
  3. New Spoiler- A little different then the OE rest....:)
    By m3steve in forum Pacific Northwest - US
    Last Post: 05-28-2008, 04:54 AM
  4. Replies: 5
    Last Post: 04-05-2002, 10:46 PM
  5. Little help from the convertible folks?
    By Puzzled1 in forum 1991 - 1999 (E36)
    Last Post: 11-15-2001, 05:06 PM
