Anybody have a full shot of the underbody of our car? The flatter most complete picture would be best. Thanks!
Sent from my SM-G930R4 using Tapatalk
I'd prefer directly under if possible. Thanks tho
what is it you're trying to see, i may have a pic or two.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
Trying to figure out best routing of my custom exhaust I am putting together. And to be able to lay it out on paper would be ideal if possible.
Not my car, but I was looking for something else on my computer and came across these, and then remembered about your thread.
and a quick panoramic
Also if you want some good pictures of an exhaust and the bends OLD MAN has some shots of his system: http://www.factoryworks.com/320iexhaust.htm
'81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
Perfect!!!! Thank you so much!
I've noticed that some are running their exhaust under the rear axle. The factory location was over the rear axle. I would think there was enough room to go over with 2.5" exhaust. Other than ease of installation, is there any other reason to run the exhaust under the axle? What, if any, are the negative effects of taking the shortcut under the axle with the exhaust?
Im running a medium case diff with e30 diff carrier sectioned into my subframe. It doesn't allow for the exhaust to go over the subframe anymore, so I'll need to go under subframe now. I'll most likely be running a frame clearance oval section under subframe to give the most ground clearance
Update the thread with tons of pictures once you get that sorted. I currently have my duals running under the axle, working on a solution to route it back up and over even with a medium case diff. I may mock up and e28 subframe to see if I can get the clearance back. I have the supersprint b-pipe and racing duals waiting to get installed.
I am also interested i have some 3" pipe to route.
I ordered some 2.5" SS mandrel bends that should be here Thurs. So I will start with the routing this weekend most likely.
