Results 1 to 22 of 22
Thread: Need help lug nut issue.
    Nov 2016
    North haven CT USA
    BMW MERCEDES BENZ
    So I ordered all new lugs for the car. I figured I would go around and make sure all come off and put some antisez on them. All went well except one. There's ALWAYS one. I have tried everything they make and sell for stuck and now stripped lugs. When i say stripped I mean rounded to the point of no return. I'm also looking to get my rims refinished and have some curb rashes fixed and freshen up. Anyway. Can anyone sugeat how to get this lug off? It's really bad and I'm at the point where I'm gonna have to drill it and try to extract it but not sure what size bit and bolt extractor to use. Here is a pic of the lug. When i say it's completely f... it's F............
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Take one of your lug bolts with you and visit a Auto Supply house or hardware store and purchase a easy out and PB Blaster.
    Nov 2016
    North haven CT USA
    BMW MERCEDES BENZ
    Quote Originally Posted by jtbgonesailing View Post
    A easy out? You mean a bolt extractor kit right?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Nov 2016
    North haven CT USA
    BMW MERCEDES BENZ
    Quote Originally Posted by Nick91303 View Post
    This kit has sizes from 1-6 for extractors aka easy out. And yea I plan on getting a can of PB... I just wanted to make sure that this was kinda my last resort lol. My new lugs will actually be here today so that is a good thing.
    Jan 2016
    Ca
    2001 525it
    Or go to a tire store and have them get it off with the tools they use when you don't have the key to get the locking lug nut off
    Oct 2007
    Ft Lauderdale
    07 530xiT, 05 CLK500 Cab
    THIS is something I would have professionally done....there are tricks to it.
    BMWCCA # 12660
    PCA # 1994019867
    2019 Porsche Macan S (75% Mine)
    2018 M/B C 300 Cabrio AMG (wifes)
    2003 Porsche 996 Cabrio 6 speed (99% mine)
    ***FOR SALE 2007 BMW E 61 530xiT
    I WILL BE NEEDING A BMW E 30 CABRIO SOON
    2014 M/B GLK 350 (awful car, lease) gone
    2005 M/B CLK 500 AMG gone
    3 Z3's (gone)
    2006 911 S Cabrio (gone)
    4 Boxsters (gone)
    2006 X5 3.0 (gone)
    1999 528iT (gone)
    1994 525iT (gone)
    7 Assorted 911's (gone)
    60 others (gone over 70 years)
    Dec 2015
    Boston, MA
    2007 BMW 530xiT
    wow, you really got yourself in a pickle on that one. i think an extractor is your best bet.
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    Personally I would just drill the head off. After that you can just unthread the remaining from the hub. Get good drill bits.start with a smaller one 1/4" then use a 1/2" or 9/16" even better
    Dec 2015
    Boston, MA
    2007 BMW 530xiT
    Quote Originally Posted by jeffkniseley View Post
    maybe i'm not picturing what you're saying, but they are tapered lugs so even if he drills the head off, as long as the tapered part is still intact, it will prevent the wheel from being removed.
    Feb 2012
    Elkhorn wisconsin
    325i 330xi 740il
    The lug nut thread is 14mm in diameter. If he drills it with a 9/16" drill that is .5625" 14mm is .5541" the taper will not be attached to the threaded part of the the lug bolt
    Dec 2015
    Boston, MA
    2007 BMW 530xiT
    got it. makes sense now.
    Take it to a professional before you make it any worse.
    And, I'm fairly certain the thread pitch on an E60 is 12 x 1.5. They didn't start using the 14 x 1.25 until later models.
    Or, does a 12 x 1.5 thread pitch actually measure at 14 mm and not 12 mm?
    Mar 2008
    Napa, Ca
    1987 M6
    I also recommend going to a shop. I can't imagine the cost being huge. Just take the new bolts with you and have them address that one wheel. You can change out all the others.
    Otherwise, the drilling out recommendation is the way to go. If you decide to drill it out on your own, start with a smaller drill and work your way up the size range. When you size up to the thread diameter at the base of the cone, the head should release. A second approach is to drill to a couple sizes under the threads, then use a hammer and chisel to smack/shear the head of the bolt when the bolt sidewalls are thin. Yet another less known trick is to try left handed drills. As they cut into the bolt, they also vibrate it and apply removal torque. In some cases, the drilling alone ends up backing out the bolt, but wheel lug bolts are on at pretty big torque.
    Jose
    1987 M6
    Livin the dream!
    Jun 2006
    nyc
    BMW 6spd 550i w Sport Pk
    It depends on the shop...here in the Bronx these idiots had no clue what to do. I took my car home, broke out the blow torch, heated that sucker for five minutes straight, then took one of those stripped bolt adapter kits from Craftsmen to the lug. It came right off immediately. I didn't use any drill bit, etc.
    North Carolina
    '86 M635/'10 Clubman
    I don't know how well an easy-out will work on something that has been torqued to 90 ft/lb
    I'd take it to a good tire shop...
    Jun 2006
    nyc
    Quote Originally Posted by e24mpwr View Post
    Don't knock it before you try it.....heat my friend. Works wonders
    Aug 2016
    Next to Snowden
    Not a BMW that's for sur
    Quote Originally Posted by Big Chaze View Post
    Yep, I did that when I bought a car with locking lugs and no key. O'Reilly's had a kit for removing those keyed lugs, and my Milwualkee Fuel M18 impact wrench took it right off. Pretty much made it clear that that "locking lugnuts" are so easily defeated it's not even funny.
    Nov 2016
    North haven CT USA
    BMW MERCEDES BENZ
    Quote Originally Posted by Norskie View Post
    Well I ended up cutting the head off. Now I just have to get the rest of the stud out. This thing is like frozen in there. I can't get over how much of a pain in the A$$ it was.
    Aug 2016
    Next to Snowden
    So you you have the wheel off and room to work now ?
    Drill the stud out, use heat and penetrating oil.
    Nov 2016
    North haven CT USA
    BMW MERCEDES BENZ
    Yeah that's what the plan is. Gonna take rotors off and have at it lol..
    Mar 2008
    Napa, Ca
    1987 M6
    Remove the disk, then hit the bolt with some PB blaster several times, over the course of a few days. There should be enough bolt sticking out that you can get a pair of vice grips on it and wiggle it a tiny bit to break the stiction. If that doesn't do it, then I recommend welding a nut to the exposed bolt piece so you can get a wrench/socket on there.
    Jose
    1987 M6
    Livin the dream!
    Aug 2016
    Next to Snowden
    Quote Originally Posted by DaHose View Post
    Or a plumbers wrench (more leverage, bites harder the more you turn it)
  1. Need help with idling issue
    By joyfret in forum 1996 - 2003 (E39)
    Last Post: 03-09-2006, 06:28 PM
  2. Need help with rubbing issue..
    By atlantisvip in forum 1991 - 1999 (E36)
    Last Post: 12-12-2005, 07:27 PM
  3. Need help. Removing nut from top of strut shaft
    By joenationwide in forum 1992 - 1999 M3 (E36)
    Last Post: 12-25-2004, 12:44 PM
  4. Need help on amplifier issue, totally stumped
    By Lahight in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-29-2003, 03:05 AM
  5. Need help! Wheel bolt issue!
    By M50E30 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-10-2002, 06:07 PM
