Page 3 of 3 FirstFirst 123
Results 51 to 60 of 60
Thread: [E36] Wrong master key from BMW
  1. #51
    South Carolina
    2004 330 vert 2004 X5
    Quote Originally Posted by bl00keRs View Post
    But would the starter kick on with this security system activated?
    Skickat från min LG-D802 via Tapatalk
    No
  2. #52
    Apr 2014
    UK
    1995 BMW 328
    ^Except when the OP has bypassed the EWS unit, which they have
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
  3. #53
    South Carolina
    Quote Originally Posted by E36328Coupe View Post
    There's several conversations going on here so....
    Perhaps I should have qualified my statement. On cars produced before 1/95 there is no EWS2. That means no chips, no antennae rings etc etc. Those cars use "Double Lock". When those cars are put into double lock they will not start until the doors are unlocked. So if you get into one of them and reach outside and put the car into double lock the car will not crank.
    On cars produced after 12/94 they use EWS2. In those cars you can get in, lock the doors and the car will start normally with the doors locked. However if both cars are locked with a key in the door you cannot unlock them from inside the car.
  4. #54
    May 2017
    Machu Picchu
    1996 E36 328 Coupe
    Guys sorry for so long time but I haven't had time yesterday. I screen recorded everything from INPA today and will upload it tomorrow. I plugged back my EWS module and no crank at all and I couldn't even go inside Body/EWS in INPA just get some error message and as fast as I jump EWS, the starter spins and try to crank the engine.
    I can't imagine it's anything else than ignition/antenna ring/transponder/key/dme/ews which could be broken. The car was behaving like normal just 1 day before it suddenly stopped to crank at all.
    I would like to invest in new parts. The car can't just stay parked 3 months now and it's sad. Summer is gone in Sweden very soon or at least a little bit of the sun gonna be gone soon. I'm ready to buy a DME, EWS II and key chip. Is that all I need? What's about aligning these new parts to my car? Is it just to swap them and that's it?? Dot need to be same car as mine? I can actually get a set of these 3 parts for about 100 bucks but they coming from an E36 320 from 08/98 and my car is from 12/95 an E36 328.
  5. #55
    Apr 2014
    UK
    1995 BMW 328
    I believe if you swap a matched set they usually just work together because people without INPA have been doing that in engine swaps for years
    Quote Originally Posted by flyfishvt View Post
    Yep I know I've read the PDF. However, my point is the OPs car would not be behaving typically so it could not be used as a diagnostic sign
  6. #56
    Apr 2014
    UK
    1995 BMW 328
    ..................unless it's just a defective pickup ring on the steering lock
  7. #57
    May 2017
    Machu Picchu
    1996 E36 328 Coupe
    I was thinking the ring too but why starter kicks on even when theres no chip inside the key? And what's matched set?
  8. #58
    Apr 2014
    UK
    1995 BMW 328
    The starter only works with no chip when you bypassed the EWS module, which is how it is supposed to work and what you said in post 54
    Matched set mean not a load of mixed up components but a working MATCHING set from another car
    Have you read this? http://www.e38.org/EWS.pdf It may help with your understanding
  9. #59
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    No. There would be no effort made whatsoever to start the engine. Go to an automatic transmission equipped car and move the gear selector away from P or N, then start the car. The ZKE gives the same result. Nothing at all happens.
    It is not a question of cranking over but failing to fire, it is a giant nothing. No crank, no nothing.
  10. #60
    May 2017
    Machu Picchu
    1996 E36 328 Coupe
    Here is some INPA live data. Only ignition on. No start ups.
  1. Replies: 2
    Last Post: 04-20-2013, 08:30 PM
  2. Master key from valet key victory!
    By Jay535is in forum 1978 - 1987 (E23)
    Last Post: 12-11-2012, 10:04 PM
  3. E30: Telling an aftermarket Master Key from Valet Key
    By PattonD in forum 1983 - 1991 (E30)
    Last Post: 08-29-2011, 01:59 PM
  4. Replies: 6
    Last Post: 01-22-2008, 07:09 PM
  5. Lost Ignition Key, Ordered key from BMW doesnt work!!! help
    By bmwpower007 in forum 1991 - 1999 (E36)
    Last Post: 01-18-2007, 04:17 PM
