Results 1 to 5 of 5
Thread: DIY troubleshooting PDC system fault
    Sep 2014
    Perth, Australia
    '92 740iL + '85 M635CSi
    Can anyone please recommend a good place to start with tracking down a PDC fault? There is nothing obviously wrong with the system from driving the car. It seems to be working exactly as designed, but the car diagnostics say otherwise. I suspect there's a dead ultrasonic sensor in one of the bumpers not doing its thing, but how do I scientifically test them to find which one it is?
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    Well could you not just cover each sensor one by one until you find one not responding right?
    ______________________________
    1992 750iL
    Jul 2016
    Chicago, Illinois
    are slow
    That's how it's done in the E39 world.
    Replace all the sensors and call it a day.
    tmaxx445's Avatar
    tmaxx445 is offline E38 6 Speed Club Member! BMW CCA Member
    Dec 2010
    Greensboro, NC
    '05 M3, '03 X5, '01 740i
    Easiest thing to do it plug up a high level BMW scanner and pull fault codes from the module if you are getting the long beep and flashing indicator light. Alternatively if you get really close to each sensor while the system is on you should be able to hear a high pitched clicking or buzzing from each. Whichever ones are silent generally need to be replaced.
    2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
    2005 M3 Coupe
    / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
    2003 4.6is X5 / Stock /
    Sep 2014
    Perth, Australia
    Quote Originally Posted by tmaxx445 View Post
    Just done this and not unsurprisingly, it turns out to be an intermittant fault of the left centre rear sensor. Sometimes it works, sometimes it doesn't. The other seven sensors appear to be reliable, it's just this one centre rear one in the bumper that seems to have a problem.
  1. Pictorial DIY: Air Conditioning System 3 Minute Troubleshoot and Recharge
    By delmarco in forum E46 Common Problems and DIY Fixes
    Last Post: 10-12-2016, 03:42 PM
  2. Anyone know what Secondar system fault is
    By xdci21 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 07-12-2010, 12:49 PM
  3. Slow right turn signal - DIY troubleshooter
    By fkarbarz in forum 1992 - 1999 M3 (E36)
    Last Post: 04-22-2008, 04:04 PM
  4. ARG...Secondary Air System Fault
    By BimmerDude18 in forum 1991 - 1999 (E36)
    Last Post: 09-16-2005, 12:37 AM
  5. Need help w/ schizophrenic PDC system.
    By roadsleeper in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-10-2002, 02:45 PM
