So a few weeks ago I'm driving down the highway and I noticed part of my instrument cluster had gone out. Gauges were still working properly but all the lights had gone out. No more turn signals, time/odometer/trip, etc. The next time I started my car, the gauges went out. At this point nothing on my instrument cluster was functioning - minus the e-brake light on the right side.
I went through the process of checking fuses - no joy. I then disconnected my battery and took the instrument cluster out to give it a look. I hit it with some compressed air for good measure, put it back in and reconnected the battery. Sure enough, the entire cluster came back to life.
A few days go by, and it craps out on me again while driving. So again... I go back and disconnect/reconnect my battery - yet again, it goes back to working perfectly.
I've now had to go through this a few times. Sometimes it will die on me within hours of reconnecting, sometimes it's a few days. So there doesn't seem to be any sort of pattern.
I'm now in the habit of just dis/reconnecting my battery every time it goes out.
I ASSUME my cluster is dying on me... but I was curious if it could be anything else?
Use the hidden OBSC menu to activate the cluster self test.
http://forum.e46fanatics.com/showthread.php?t=463376
Check for corrosion and clean connections with electrical contact cleaner.
Btw,e36 or e46?
Ok I'll give that a shot. It's an E46. 2002 325ci
I've run the 2 (test) and everything goes as it should. Maybe run the 1.4 diagnosis function?
