Results 1 to 2 of 2
Thread: cant diagnose code
    Aug 2013
    michigan
    2002 330 xi,1972 nova 38
    cant diagnose code
    Greetings all semi-proud owner of 2002 330xi ( i prefer to work on my 72 nova :-)) a lot less wires!
    Anywhy, the reason for the post is i am plagued by a misfire/lean running issue
    I have a scan tool and it is reading the following codes
    -p0171 and 174
    -Along with the misfire detected low fuel code (dont have that exact code memorized)
    the codes would appear randomly then literally go away within a few hours
    -One of the things i noticed is that it was more common whenever i would fill up at a gas station (was thinking loose gas cap) but I am extremely hesitant sayin that is the issue
    -The short term fuel trim levels on bank 1 and 2 are fine (15.6%),however the long term fuel trim banks are way off according to the scan tool (11.7%)
    -it is up to date and has been on fluid changes etc......
    -checked the lower intake boots didnt see any cracks nor did it rev wen i used the carb cleaner test
    - MAF sensor is good tested that and its working as should
    - i did notice a while back that when using a injector cleaner additive in the gas tank it would prolong theses light from coming back
    -little suction when removing the oil cap at idle
    and the ccv tube appears clear
    any ideas?
    someone suggested using a sea foam spray treatment on it?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Yes P0171/0174 are classic vacuum leak codes normally. While you can check the upper and lower boots, it is possible that your CCV system has a crack in one of the tubes. My recommendation would be to find a shop that can do Smoke testing, and have them hunt down the leak.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. need help with diagnosing codes
    By Matsui in forum 1995 - 2001 (E38)
    Last Post: 11-17-2006, 05:01 PM
  2. Cant read codes???
    By Mr brown in forum 1996 - 2003 (E39)
    Last Post: 10-01-2006, 07:16 PM
  3. cant check codes with gas pedal trick
    By notownsurf13 in forum 1991 - 1999 (E36)
    Last Post: 07-27-2006, 07:25 PM
  4. cant get codes
    By ukbyoung in forum 1992 - 1999 M3 (E36)
    Last Post: 11-11-2005, 08:43 PM
  5. Need some help diagnosing codes...
    By Mpowered02 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-27-2005, 05:38 PM
