Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: E46 - Is it possible to code 5 Blinks on One Touch Indicators Function
  1. #26
    Philadelphia, PA
    2005 M3 & 2004 330i
    Depends on hardware/software revision of the module.
    I don't think any E38/39/53 LCM supports triple blink.
  2. #27
    The Netherlands
    DE-spec E36 328i/M3 cab
    Quote Originally Posted by TerraPhantm View Post
    I can confirm this.
    I also know an old website that made comfort blinkm modules for (among) the E38. Which would be useless if the car had this function.
    No coding index of the LCM/LSZ has this parameter.
    In my E36 I use an aftermarket, programmable (1-12 blinks) unit the size of a matchbox to have this function.
    IG:
  3. #28
    Mar 2017
    Indonesia
    E46 325i
    Hi, Terra.. i'm sorry out of topic.
    I installed m3 cluster 2004 CI:24 in my e46 325i 2001, the problem is ASC light stay on. Could it be fix by ncsexpert?
    Thanks, i hope you answer my question.
  4. #29
    The Netherlands
    NCS Expert is for coding, not diagnosis. Try INPA to see if there is a fault stored and if so reset it and see if it stays away.
    IG:
  5. #30
    Mar 2017
    Indonesia
    E46 325i
    Hi, thanks for answer. I try to diagnose by INPA, nothing error store in ASC module but ASC light stay on in the m3 cluster.
  6. #31
    Jul 2004
    Houston, TX
    36 Cylinders
    You need to code the DSC system again when you have another cluster. Yes, this is with NCS Expert.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  7. #32
    The Netherlands
    Ah yes, if it's a coding related issue of course NCS is what you want to use.
    Otherwise I would've suggested to read the Kombi for faults.
    IG:
  8. #33
    Mar 2017
    Indonesia
    E46 325i
    Recode my ASC module? Oke, i'll try it after work, by the way my module is ASC not DSC. Thanks!
    Quote Originally Posted by MParallel View Post
    Yaa i've read the kombi using pasoft, show fault "No Can Message". What is mean? Thanks!
  9. #34
    Philadelphia, PA
    2005 M3 & 2004 330i
    DSC is probably fine as long as the VIN matches. Cluster needs to be recoded. M3s come coded differently than non-Ms, and early and late cars ahve some differences too.
    Easiest way to deal with it is to change the coding index from 24 to 08 with PASoft, then code it as if it's a 325i cluster via NCS Expert.
  10. #35
    The Netherlands
    Interesting. I somehow thought the coding index was hardware related.
    IG:
  11. #36
    Jul 2005
    Sacramento, CA
    70hp of fury
    It's called an LCM on non Xenon E46s. Speaking of which, anyone have a link to the software?
    '89 325i = 15.6@91
    '03 325i 5spd sedan.
  1. Is it possible to fit 24s on my 93 740i?
    By Bstevens12 in forum 1988 - 1994 (E32)
    Last Post: 05-10-2013, 11:42 AM
  2. Is it possible to rollback miles on an e36
    By iwannadinanm3 in forum 1991 - 1999 (E36)
    Last Post: 05-02-2011, 07:05 PM
  3. Is it possible to install vanos on a non vanos transmission
    By jmore1231 in forum 1991 - 1999 (E36)
    Last Post: 05-11-2010, 09:33 AM
  4. Is it possible to change direction on Steptronic??
    By helvetica in forum 1996 - 2003 (E39)
    Last Post: 03-03-2009, 06:19 PM
  5. Is it possible to have E46 door handles on my E36?
    By Andre325i in forum 1991 - 1999 (E36)
    Last Post: 03-31-2001, 02:17 AM
