Results 1 to 25 of 36
Thread: E46 - Is it possible to code 5 Blinks on One Touch Indicators Function
    Dublin, Ireland
    2000 316i Compact
    Hi all,
    I have a new LCM with software version v4.5 and the One Touch Indicators is working perfectly. However, it only flashes 3 times but I would really wish it could flash 5 or 6 times.
    I fired up NCS Expert and extracted the details of the LSZ module. However, when I use NCS Dummy, it only presents two options - "einmal" (one time) or "dreimal" (three times). Does this mean that it's impossible to set this module to 5 blinks ?
    Jul 2004
    Houston, TX
    36 Cylinders
    You have to make a custom daten file (which one are you using? .C37? ), which replaces the 03 (dreimal) to a 05 or 06. But don't change the name "dreimal", just the number.
    or Nettodata coding, if possible.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Philadelphia, PA
    2005 M3 & 2004 330i
    You can also add new parameters with NCS Dummy and name them whatever you want. Maximum supported value is 7
    Dublin, Ireland
    2000 316i Compact
    You have to make a custom daten file (which one are you using? .C37? ), which replaces the 03 (dreimal) to a 05 or 06. But don't change the name "dreimal", just the number. or Nettodata coding, if possible.
    I cannot delete the old dreimal nor can I edit the value. And since I cannot delete it, I cannot add another with the same name
    Quote Originally Posted by TerraPhantm View Post
    As 328 Power 04 said, it seems that I must add the value against the word dreimal since I think the program doesn't understand any other words.
    Any ideas as to what to do next ?
    Jul 2004
    Houston, TX
    36 Cylinders
    You missed the point.
    You need to edit the daten file itself for custom coding options not regularly available, not the text based interpretation of simple coding.
    This means you have to disassemble your daten file (this is the reason why I asked you which daten file version you were choosing, that was an important question), make your custom option available.. then assemble the daten file back. THEN you code the module.
    Or google "nettodat coding".
    Both ways are a bit above level complexity, when compared to the usual coding of predetermined options.
    Also, what terra said is new to me, but actually a very nice feature, that I never knew about. You can actually create new options, with your own naming.
    Right click in the area of your options and see the "Add Parameter" button. Add your parameter, then go to "Update Module" to save the custom daten file.
    This will give you the option to update the daten file with new custom data easier.
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    Also, make sure you are using NCSDummy correctly by actually loading your .trc file... instead of only using NCSDummy as a reference.
    -Abel
    Dublin, Ireland
    2000 316i Compact
    Thank you so much guys. I've now got 6 blinks working and added the choice of 5 or 6 to the existing 1 or 3 blinks. So by adding parameters, I then updated the module, all using NCS Dummy. Part of my problem was not editing the Expertprofile and enabling the writing using the MAN file. So I think I kept writing back by read out TRC file.
    For the benefit of others, it was indeed the .C37 custom daten file. You simply fire up NCS Dummy, select the Module LSZ.C37 and left the Trace file Blank. I then found CYCL_TI_BLK and added two new parameters called five value 05 and six value 06 and then clicked Module Functions > Update Module. It's then a case of existing and running NCS Dummy again with importing the TRC file this time, selecting the value five or six and writing the MAN file before then re-coding the car with NCS Expert.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Also make sure to check the mask size the parameter is in. If it says 00..01 for most on/off functions, only 2 possible parameters can be there.
    If the mask is 00..FF (it's hexadecimal), than you can have 255 parameters max.
    I've played around with the E36 window-drop parameter for coupe/cabrio which sets the amount of drop. You can even have the window open fully, for example.
    Handy for when the drop doesn't clear the rubber seal properly anymore.
    IG:
    Sep 2010
    Estonia
    2000 BMW 740i
    Is this feature also available to E53 X5? I only want 3 times flashing.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Volum View Post
    Yes, but it really depends on module version
    -Abel
    Sep 2010
    Estonia
    2000 BMW 740i
    What is the option called?
    Dublin, Ireland
    2000 316i Compact
    CYCL_TI_BLK
    Sent from my LG-D855 using Tapatalk
    Sep 2010
    Estonia
    2000 BMW 740i
    What module?
    Dublin, Ireland
    2000 316i Compact
    Lsz
    The Netherlands
    Interesting. I thought the mask size, in this case "00..07" meant a maximum of 7 parameters. Never realized it was the maximum allowed value.
    Does make sense.
    IG:
    The Netherlands
    BMW 330CI DropTop
    Quote Originally Posted by MParallel View Post
    Interesting,
    This is something I was looking for, do you know which parameter need to be change to drop the window a little more for the E46 convertible?
    Sep 2010
    Estonia
    2000 BMW 740i
    Quote Originally Posted by championc View Post
    Lsz
    You mean LCM?
    Jul 2004
    Houston, TX
    36 Cylinders
    Lichtschalterzentrum ?
    -Abel
    Sep 2010
    Estonia
    2000 BMW 740i
    Yes I know what LSZ means, but I have only LCM to pick, not LSZ.
    Dublin, Ireland
    2000 316i Compact
    Strange, almost everyone else will confirm that they only see LSZ and no sign of LCM.
    Use whichever of the two you see
    Sep 2010
    Estonia
    2000 BMW 740i
    When using LCM, there's no "CYCL_TI_BLK"
    Dublin, Ireland
    2000 316i Compact
    I have no idea as to what you are doing but i think you are the only person seeing a module called LCM.
    So sorry, i cannot help you.
    You have an E46? You are using NCS Expert and the NCS Dummy ?
    Sep 2010
    Estonia
    2000 BMW 740i
    I was talking about E53.
    Jul 2004
    Houston, TX
    36 Cylinders
    Depends on hardware/software revision of the module.
    -Abel
    Sep 2010
    Estonia
    2000 BMW 740i
    Seems like it isn't possible. To my e53 at least.
  1. Is it possible to fit 24s on my 93 740i?
    By Bstevens12 in forum 1988 - 1994 (E32)
    Last Post: 05-10-2013, 11:42 AM
  2. Is it possible to rollback miles on an e36
    By iwannadinanm3 in forum 1991 - 1999 (E36)
    Last Post: 05-02-2011, 07:05 PM
  3. Is it possible to install vanos on a non vanos transmission
    By jmore1231 in forum 1991 - 1999 (E36)
    Last Post: 05-11-2010, 09:33 AM
  4. Is it possible to change direction on Steptronic??
    By helvetica in forum 1996 - 2003 (E39)
    Last Post: 03-03-2009, 06:19 PM
  5. Is it possible to have E46 door handles on my E36?
    By Andre325i in forum 1991 - 1999 (E36)
    Last Post: 03-31-2001, 02:17 AM
