Results 1 to 11 of 11
Thread: Need help! 2004 645Ci engine noise...
    Jun 2017
    Lusby, MD
    2013 740LiX, 2004 645Ci
    Hello,
    Recently bought a 2004 645Ci at auction... it had upper engine noise and some misfiring...took care of that with upper engine clean, oil change, and new spark plugs (looked like low grade oil and 89 fuel had been used...bought from sherrifs dept)
    So anyways, the issue I need help diagnosing is what remained -- a 'chugging' noise, most noticeable at idle and initial acceleration; hardly noticeable over 1500 RPM.
    I posted two video on YouTube for your consideration:
    video 1 is about 18 seconds: https://youtu.be/6nAVQTIvT7Y
    video 2 is about 80 seconds long, and is of engine running at idle then accelerated to 1500 rpm, then idle with a/c on then off: https://youtu.be/bSnzieHReqw
    I removed the fan belt to test if one of the external components...no change (I did not remove the compressor belt).
    Any thoughts or insight to what this might be would be greatly appreciated!
    Thanks!
    May 2017
    USA
    E90, E46
    Sounds like a collapsed lifter...
    by watching a video it's tough to tell wether it's top end or bottom end
    Jun 2017
    Lusby, MD
    Quote Originally Posted by SlackTube View Post
    It sounds, to me, to be coming from lower front...can't tell if left or right...
    thanks .. I'll keep collapsed lifter on my list of possible issues.
    cheers!
    Feb 2015
    Athens, AL USA
    E60, E46
    One more thought for the lower front end is the chain tensioner. Add that to your list...Mine is more towards the back on bank 2. I have replaced all the injectors on engine and 8 lifters on 7 and 8....rear two pistons. Next is the vacuum pump....don't really understand how that works but its another common failure for these engines. good luck
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    See:
    https://www.bimmerforums.com/forum/s...5#post29982135
    By the way, there is a way to puff-up a collapsed lifter which has been a problem since the introduction of the M60 V8 engine:
    http://www.meeknet.co.uk/E38/Tappets.htm
    and more information here:
    http://www.meeknet.co.uk/e31/BMW_M60...ary_Noises.htm
    My BMW Repair YouTube Channel
    Jun 2017
    Lusby, MD
    Thanks ugeeks,
    Haven’t had time if late to work on the 645, I’ll probably get back to her next month.
    Will post my success (or failure).
    cheers
    Jun 2017
    Lusby, MD
    Hello Timm,
    Thanks for the information and links! I enjoyed the articles - your site is great!
    Am I understanding correctly, if the vacuum pump is the issue I will likely see leakage of oil around the pump housing?
    thanks again, appreciate everyone’s help.
    cheers
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Thanks! No, the oil leak is an additional 'feature' of the vacuum pump apart from the noise it can make.
    Jun 2017
    Lusby, MD
    Thumbs up
    Thanks... I checked the pump this morning for sound, and minimal “rubbing” or “shewshing” sound only...but will work that and the lifters when I get some more time.
    Oh and there is clearly oil coating over the vacuum pump .
    thanks again👍
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It isn't the pump that makes the noise - it transmits the noise down the camshaft - try removing the blanking cap as seen below when the engine is running, if that makes no difference your vacuum pump worries are over!
    Jun 2017
    Lusby, MD
    ok. Thanks.
  1. Need help diagnosing M42 Engine Noise
    By AK2799 in forum 1983 - 1991 (E30)
    Last Post: 04-25-2014, 04:23 AM
  2. Need Help Diagnosing 540i Engine Noise Video Inside
    By cis8vgti in forum 1996 - 2003 (E39)
    Last Post: 11-17-2010, 07:23 PM
  3. Need help: 2004 M3 with RGRs
    By DieselAzn in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-27-2003, 04:00 AM
  4. Need help to buy engine... Thanks
    By Saul in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-25-2003, 02:34 PM
  5. Need help with a strange noise.....
    By back_in_black in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2003, 12:49 PM
