Results 1 to 12 of 12
Thread: Flywheel weights
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Flywheel weights
    I need a new clutch in the E36 M3 w/ stock motor w/ basically stock power. The car is dedicated to track events/TTs, but is street legal and driven to/from the track. I don't care about noise, but it has to be usable in traffic (i once spent 2 hours in stop n go on the way to NJMP).
    I'll likely go with a Gripforce/FX option as I'm adequately satisfied by the feedback i've been reading and the price is right. I plan to go with a "Stage 1" organic/OEM type clutch or maybe a "Stage 2" kevlar.
    I'm debating between the 14.5lb chromoly flywheel and the 10.6lb aluminum flywheel. What do you guys think?
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by TXBDan View Post
    Go chromoly. I have the stage 3, and it is definately streetable to and from the track....
    Oct 2003
    Seattle
    99 M3
    Flywheel weights
    I run a 10.5 lb aluminum w/Kevlar M5 disk. I would go organic in the future. All street use. I've done a couple demonstration laps in a couple sessions as a CCA instructor.
    Love the heel-toe throttle response.
    Boston, MA, USA
    '99 M Coupe
    Once?! I don't think I've ever spent less than 2 hours.
    Dan Chadwick
    Boston Chapter BMW CCA Instructor Development.
    Near-Orbital Space Monkeys, E30 M50-ish
    Driving Evals on-line evaluations for Driving Schools. Paper forms are just wrong.
    Nov 2005
    MA
    I think i'm about to pull the trigger on the 10.6lb aluminum with OEM organic rigid disc and HD pressure plate. My only hesitation is that the disc is rigid and not sprung, but i assume it works. I don't care about noise.
    http://gripforce.com/fx-racing-stage...3-e34-e36-e39/
    On eBay this kit is only $429. Wild.
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Wow. THat's a great deal.
    Any longevity/ reliability concerns going with a light weight flywheel? I haven't done enough research on it.
    Thanks,
    99 M3 STU/ GTS3 Project
    Springfield, IL
    Quote Originally Posted by NotoriousJJE View Post
    Thanks,
    There is some suspicions regardong their effect on drivetrain harmonics and the OPN..... That is part of the reason I went chromoly. That and the chatter is supposedly reduced.
    Oct 2003
    Seattle
    99 M3
    Flywheel weights
    Really want to use spring disk with single mass flywheel.
    Engine harmonics is a problem in the lower RPM range ~ 1500 to 2500.
    The collector on one of my stock head pipes fractured off in the early days of my LWT FW.
    MD
    99 M3 / 95 325i
    Engine harmonics also big issue at high rpm. I am most likely ditching my LWFW setup (JBR)
    Sent from my Nexus 5X using Tapatalk
    -Chris
    Florida and ATL
    1999 M3 and 1990 Jetta G
    Quote Originally Posted by ThreeD View Post
    Your review of JBR was one of the reasons I was considering it... what's changed in your experience? Would you go with a slightly heavier chromoly FW? Or right back to dual-mass stock?
    MD
    99 M3 / 95 325i
    Quote Originally Posted by propcar View Post
    Harmonics issue that may be specific to just my engine. I'm probably going back to DMF.
    -Chris
    Nov 2005
    MA
    I know a guy with the light aluminum JB w/ OE rigid clutch disc and says it works great. I assume the FX Racing version is similar. There would be less damping than with a factory DMF or even heavier flywheel, but i figure bimmerworld must sell a shit ton of these so they must be relatively ok. Just don't rev above 7200rpm where things get wonky with our bottom end.
    tl;dr: I haven't heard enough noise on the various forums to be too afraid.
  1. Different flywheel weights? What's out there?
    By I3MW in forum 1992 - 1999 M3 (E36)
    Last Post: 07-27-2008, 01:10 AM
  2. custom turbo flywheel weight? suggestions accepted
    By Black Mamba in forum Forced Induction
    Last Post: 10-22-2007, 11:55 AM
  3. Stock Flywheel Weight Difference Between 3.0 & 3.2
    By rommelrules in forum 1992 - 1999 M3 (E36)
    Last Post: 03-20-2006, 04:15 PM
  4. m50 flywheel weight
    By ShoreBimmerBoi in forum 1991 - 1999 (E36)
    Last Post: 11-03-2005, 10:19 AM
  5. e36 M3 flywheel weight
    By Milo in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-28-2004, 09:07 PM
