Does anyone know where the fuel pressure regulator is for a '97 M3/4? Does anyone have a diagram from the shop manual?
Thanks,
TechnoV
It is located under the car just in front of the fuel filter. It is a small round metal object. It is on the drivers side roughly near your feet would be when in the car. You will need to remove a metal protector panel to gain full access.
== Stable mates ==
-1996 M3 Lux, bright red (hellrot), Modena interior. Aus Freude Am Fahren!
-1988 325, Alpenweiss. The commuter.
BMW HOWTOs
I have a European M3 3,2L. As far as I know, my fpr and yours are the same.
Mine is located under the fuel rail, right in front of the 6th cylinder.
To get it out is a big job.
But it is made of plastic, so you cannot push the fpr tighter to increase the fpr pressure above 3,5 bar. If it was made of metal you could have squezzed it to increase fpressure.
MERT Euro 3,2 600+ hp 18 psi boost
Only the M/S50US engines have the fuel pres. reg. mounted on the fuel rail. Or the european engines. I believe that his is a US spec S52 so it will be under the car.
== Stable mates ==
BMW HOWTOs
Thanks guys. I haven't found it yet but I appreciate all of your help.
Technov
