Results 1 to 5 of 5
Thread: Replaced starter now no starter or speedo
    Aug 2011
    Norwalk, CT
    04 330ci ZHP, 04 Yukon
    I replaced the starter in my 04 330ci today and the first few times I started it it was fine. I drove it for about 15 mins and when I stopped i heard what I thought was the aux fan running. I just fixed my ac and thought that's why it might be running now. I came out 2 minutes later and still heard it, when I went to start the car I had no starter. Popped the hood and the sound was coming from inside or below the manifold. I popped started the car and got to my appointment. Tried again and a few times after and still no starter. Coming home I realized my speedometer only reads about 16mph. As soon as I start moving it jumps up and when I stop it drops below 0. Anyone got any ideas? I'm suppose to be taking the car on a 6 hour trip saturday morning and need everything working.
    Check out my current build pics here
    Dec 2013
    Chicagoland area
    EXOTICS
    I suspect that you disturbed the crankshaft position sensor/connection while replacing the starter,
    as they are located in the same general area.
    Aug 2011
    Norwalk, CT
    Why would it have started fine the first few times I tried it?
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    Because if you knocked it loose while working on it, running the car could have caused it to lose connection.
    Aug 2011
    Norwalk, CT
    Problem solved. The battery + wire shorted to the small terminal (the one on the top when the starter is installed, black /yellow wire). The starter stayed running and burnt out. What I didn't realize until I pulled it back out is the standoff that the battery and alt wire mount to is much shorter on the starter I swapped in. It must have moved just enough to short out as I was driving. Swapped the old one (with the longer B+ standoff) in and it started right up. Haven't been on a test drive yet to check the speedo but I was able to do an oil service reset so I'm guessing all is good. No idea why the nazi engineers designed it that way but if your speedo only reads 0 or 15 mph but everything else works and no lights on the dash then check that wire. I thought I had seen something about it in one of the searches I did but couldn't find it again. Thanks for the help
  1. Replies: 4
    Last Post: 06-13-2014, 12:13 PM
  2. Changed Starter, now no fuel
    By 82 320iS in forum 1975 - 1983 (E21)
    Last Post: 05-09-2011, 05:18 PM
  3. Pulled EWS relay now no starter or blinkers
    By the rev in forum 1991 - 1999 (E36)
    Last Post: 06-14-2010, 10:50 AM
  4. Replaced Radiator Now no Heat & Check Eng Lights Comes on
    By Wilhelm8 in forum 1991 - 1999 (E36)
    Last Post: 03-23-2006, 10:53 PM
  5. no tach or speedo- help please
    By drmcdave in forum 1983 - 1991 (E30)
    Last Post: 07-24-2005, 03:31 PM
