Order Link
https://www.x-ph.com/active-autowerke-bmw-e82-signature-rear-exhaust-n52-128i-by-bmw-tuner/
Are you looking for a combination of optimal power, performance, and sound for your car? Well, look no more because the Active Autowerke BMW 128i (N52) exhaust system is the perfect product for you! Proving superior to its predecessor, this new and improved exhaust allows 35% to 40% more exhaust flow than the stock 328i exhaust. This is mainly because of the free-flow, beefy 80mm design.
This increased flow minimizes back pressure which results in significant Horsepower and Torque gains within your engine. As well as increasing durability, the system's 100% hi-polish stainless steel construction gives it a bold, and defying visual effect. Expect a sporty, yet very mellow tone with this exhaust.
To completely eliminate drone, this exhaust features the special Active Autowerke Noise Cancellation Chamber.
NOTE:
This exhaust doesn't fit the XI (4WD) and Station Wagon Models and will require cutting factory pipe in order to install.
While some models have a round tubular pipe, other models have an oblong shape and will require welding instead of clamping.
KEY FEATURES:
Fits BMW 128i
Full 304 stainless steel construction with hi-polish finish
3" Mandrel-bent piping for optimum exhaust flow
NCC (Drone Reduction)
Dual 80mm Active Autowerke Signature tips, staggered
Weight Savings *18lbs lighter than stock BMW exhaust*
Designed to use existing factory mounts and hardware
Fully adjustable mounting positions
Fully adjustable tips
Illustrated instruction manual
Two year warranty
Coupon codes available!
