Results 1 to 6 of 6
Thread: Shifter Seems to Have Broken Off / Disconnected
    Feb 2008
    San Francisco, CA
    Jet Black 2003 M3 Coupe
    I got a new clutch about a month or so ago in my 2003 M3 and the shifter feel was roughly similar to before but would have some times where it was harder to get in gear and had to wiggle it around a bit.
    I decided I would just change the fluid and it should do the trick, but before I could get to it, my shifter completely broke today and I couldn't get it in gear at all, its just flopping around. I let the clutch out and it still was able to keep run, so I'm assuming its stuck in neutral. I was lucky it was a residential area and was able to push it more or less off to the side of the road for now.
    Any ideas what most likely happened?
    Is it likely to be fixable without needing to have a shop drop the transmission and everything all over again? (Maybe through the top of the console?)
    Any help is GRRRREATLY appreciated!
    Thanks.
    VIDEO:
    FOR SALE:
    *E36 "Luxury" Side Skirt - Cosmos Black - $100
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Get it home and in the air. Trans does not need to come down, but you'll have to work around the driveshaft / shield etc. it's not impossible. Pull the boot and get a photo of the linkage. You'll have a better idea of the issue and we can help more.
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    What did you find? My guess would be a pin was not secured when they put it back together.
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    Feb 2008
    San Francisco, CA
    I ended up buying a big jack and stands etc, and jacking the car up so I could slide underneath and sure enough the clip that holds the shifter on was missing allowing it all to disconnect...wether it popped off or was never put back on, who knows?
    I went to buy a new tiny clip at the dealer for some ungodly price and then I spent all night trying to blindly reach up through the exhaust and around the drive shaft to get the clip back on...finally got it.
    I changed my transmission fluid after that and the shifts are so smooth and easy now, its night and day.
    What a pain in the ass. I wish I could secure that clip better somehow so it doesn't happen again...
    May 2009
    Pittsburgh, PA
    Nice find! What MT fluid did you go with?
    Mar 2014
    Concord, CA
    1996 328i vert
    Quote Originally Posted by shane82388 View Post
    Ah the "bitch" clip, now you know why it's called that. Other than it being near impossible to fit large hands in there to get it I hate the fact that the tolerance on the thing is like right on the money. The security of it rests in the fact that it clips to the top of the transmission housing (slides over a fin). It's pretty secure there, I remember having to use a 1' flathead and mallet to get that thing undone!
  1. Where's that link that show how to have ASC off by default?
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-11-2003, 09:19 AM
  2. UUC TME's seem to have added a LOT of noise
    By RenaissanceMan in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2003, 01:56 PM
  3. interesting problem that seems to have gone away
    By Canatro in forum 1983 - 1991 (E30)
    Last Post: 03-29-2003, 04:53 PM
  4. Squeeling noise seems to have stopped??
    By Jim[UK]AKA 007 in forum 1991 - 1999 (E36)
    Last Post: 02-27-2001, 08:42 AM
