Bavarian Soundwerks
Results 1 to 3 of 3
Thread: e46 330d manual Battery/charging light on but 14.1volts.STRANGE.HELP!
    Dec 2014
    dundee Scotland
    e39 530d
    Today whilst driving in 2nd gear when i got to about 3500rpm my charging light came on then as quickly went off again.
    now it seems,when i get revs to about 3500rpm when in 2nd 3rd gear my charging light comes on then goes off after revs drop back down again.
    maybe nothing to do with it but could have swore i heard a higher pitched noise from somewhere behind the dash/clocks,could just be imaginig it though.
    even ifi run car stationary in neutral if the revs are quick enough once it gets to over 3500rpm battery light comes on like before.NOW....my battery voltage seems fine ie:14.1v running,maybe upto 14.3 at about 3000rpm. even when battery light comes on dash the voltage still appears to be over 14v(just).
    anyone? regulator? belt slip?(will be replacing belt tomorrow just in case!),bad gorund? checked terminals at battery and theyre fine.will have a look at alternator tomorrow.
    BTW,does anyone know offhand if alternators in 1999 330d is bosch or valeo if its the original 1?
    https://www.dropbox.com/s/x24buu0qw2...61916.mp4?dl=0
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    That voltage-14VDC-is fine. Something else is causing the battery light to come on.
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Are you able to pull the codes? It'll give you a good place to start troubleshooting.
    888.280.7799 | 6am - 5pm PST
  1. Battery Light On, but battery and alternator test good?
    By 99bimmere46 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-13-2013, 06:25 AM
  2. Replies: 6
    Last Post: 11-30-2010, 09:41 AM
  3. battery light on but altonator good?
    By WHITEXi in forum 1999 - 2006 (E46)
    Last Post: 10-24-2010, 09:44 PM
  4. Battery light on but the alternator is good....
    By dagoo98 in forum 1982 - 1988 (E28)
    Last Post: 11-21-2006, 02:08 AM
  5. Battery charge light came on
    By DUTCH50 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-14-2005, 09:05 PM
