Results 1 to 10 of 10
Thread: PA Soft on Z3?
    Bowling Green, KY
    2001 Z3 3.0i, 2001 525i
    PA Soft on Z3?
    I've searched and haven't seen much info related to PA Soft and its compatability with a 2001 BMW Z3Does anyone know, or has anyone used a PA Soft module to connect to their Z3?
    Jul 2004
    Houston, TX
    36 Cylinders
    It will work on some modules, but the common PASoft 1.4 is intended more for the newer chassis.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    PA Soft was the only software in the diagnostic suite that would readily communicate with my engine swapped 2000 2.8 coupe to reset my throttle adaptations.
    PRICE CUT on ALL FABRICS
    Bowling Green, KY
    Quote Originally Posted by BimmerBreaker View Post
    Thanks, looks like I know what to do then.Please refresh my memory, it needs a computer running WinXP correct?
    Jul 2004
    Houston, TX
    36 Cylinders
    Not really, it can run on modern computers, if you know how to tinker with drivers.
    PASoft is just meh though on e36. Much better for your e39 and e46s for LCM and cluster stuff.
    -Abel
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    I can't say I've ever tried PAsoft on a Z3. But I've done things with it on later cars that couldn't be done with other tools. Things like getting single modules out of transport mode after a weak battery causes havoc.
    /.randy
    Feb 2004
    san diego
    ...it depands
    Have you looked into either INPA or Carsoft? Personally, I would recommend either one for our cars over PASoft. But that's just my two cents.
    As 328Poewer04 mentioned above, PASoft on our cars is somewhat limiting. Unable to reset SRS was the deal breaker for me. Then again, it can be had for very cheap price nowadays so...
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Bowling Green, KY
    Quote Originally Posted by nevan View Post
    I had a 2000 e39 that I bought PA Soft for a few years ago so I've already got the setup. I'm most curious if it will read the instrument cluster as I've done some reading about a mod on the e46 cluster where you can reprogram the temperature gauge buffer so it actually moves before its too late.
    Jul 2004
    Houston, TX
    36 Cylinders
    Hmm, haven't tried with PASoft, but I've done it to the Z3s with NCSExpert, as part of the INPA pack. It works well. Don't recommend removing more than 5 degrees off the center line buffer high limit, or else the gauge will move too much. Been there done that.
    The stock gauge definitely moves up before it's too late (*when the cooling system isn't neglected, and bled properly. Air in the system is what kills the motors.)
    Since the late Z3 cluster is more like the E46 cluster, it may work with PASoft. But it was PASoft 1.36 that was intended for E36.
    -Abel
    Any details on how to do that? Ive seen it done and after some recent cooling system work id like to have a better idea of temps without always using the secret menu.
  1. Using PA Soft on Win10 X64
    By MN2K740i in forum Diagnostic Software
    Last Post: 08-30-2019, 05:09 PM
  2. ZKE-Anti Theft & SRS Error on PA Soft Scan. HELP!!!
    By jmd4ya in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-26-2014, 12:05 PM
  3. PA SOFT questions on DTCs
    By farhansadiq in forum Diagnostic Software
    Last Post: 06-28-2014, 12:56 AM
  4. PA soft unable to read code on IKE
    By 20vector in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-23-2012, 08:19 PM
  5. Replies: 0
    Last Post: 08-16-2007, 08:38 AM
