eBMWParts
Results 1 to 12 of 12
Thread: Noob - E39 with bi-polar handling
    Jun 2017
    Stillwater, MN
    2003 530iA
    Good day. I have been driving a 2003 530i for about 18 months and have noticed a very peculiar and troubling situation. In most cases, the handling is just superb - minimal body roll, well-managed impacts from expansion joints, etc. - exactly why I wanted a BMW in the first place. Then, everyone now and again, and without any overt action on my part, the suspension reverts to 1992-era Cadillac Brougham handling - the body just bobs as though the shocks are completely blown, expansion joints send a shudder through the entire car, and pothole impacts seem like a wheel is about to simply fly off the car. Then, after surviving the ride home and parking the car for a while - 30 minutes, an hour, overnight - the suspension returns to typical BMW excellence on the next drive. Sometimes the handling even improves during the same ride. Again, I am not making any adjustments in the car or flipping the automatic over into the Sport programming - it just starts to happen, leaving me both sad and nervous as hell.
    I am mystified by this bi-polar (perhaps schizophrenic is a better adjective, but I don't want to get involved in a psychoanalysis debate here) behavior. As far as I can find, BMW didn't start installing adaptive suspension for several years after my E39 was built. Has anyone else experienced this phenomenon? Any suggestions about how to diagnose what may be at fault without sending the car (and about $8,000) to my local BMW shop?
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Sounds like it just needs new shocks. I would also check to make sure you don't have any broken springs.
    Jun 2017
    Stillwater, MN
    2003 530iA
    Shocks are certainly a possibility. But why would the handling go from "fine" to "spooky"? I would think shocks would behave more consistently - if they're worn and tired, I would think the car should handle poorly all the time, not one drive in 10 or 12.
    Jul 2017
    Maine usa
    E90 330xi
    Quote Originally Posted by sstratmoen View Post
    Maybe your brake caliper sliders are sticking. If they stick it will cause the car to pull to one side which makes it feel odd
    Dec 2013
    Chicagoland area
    EXOTICS
    You have EDC problems.
    Check for suspension components by VIN#
    here:https://www.etkbmw.com/bmw/EN/index/series/3/NEW/F31N
    Jul 2017
    Maine usa
    E90 330xi
    Quote Originally Posted by MIKYZZ4 View Post
    That is a good point. Would make sense if he does have edc. It would explain the symptoms
    Sent from my SM-G930VL using Tapatalk
    Jun 2017
    Stillwater, MN
    2003 530iA
    Gentlemen - Thank you for your suggestions. As much as it seemed plausible (even likely) that the EDC module was at the root of this issue, I don't believe my car is so equipped. I used the VIN decoder recommended (thanks MIKYZZ4) and see a breakdown of options that DOESN'T list option S223A.
    Further, I found a front axle suspension page from the realoem website that shows that there should be harness components on the top of the shock tower if so equipped with option package S223A.
    The picture of my passenger side front shock tower shows that I don't have any electrical harness there.
    So, I don't believe this is what is going on that makes my handling degrade so severely. Any other ideas?
    (I'm sorry if I am posting these images incorrectly; I am hoping these are thumbnail previews and you can just click on them to see them full size).
    Jul 2017
    Maine usa
    E90 330xi
    Good work.. Guess that angle may be a bust.. Wonder if the steering column could cause intermittent issues. Curious if you have taken it into any repair shops to have them diagnose the issue.. I ask because this is one of the illusive problems of which I have had similar issues that repair shops could not find the actual problem in test drives.
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    It could possibly be brake fluid related, maybe fluid getting too hot causing effects the abs system can not handle?
    Jun 2017
    Stillwater, MN
    2003 530iA
    Junglenut - Thanks for the reply. I highly doubt it's connected to brake fluid. I commute over relatively long stretches (several miles at a time) without ever even tapping the brakes and this weird suspension defect will still occur, so I don't think that is part of this problem.
    Jun 2017
    Stillwater, MN
    2003 530iA
    This happened again to me driving home from work on July 11 and I took two videos that show the before and after. If you turn the sound up, listen to the video I took at 4:39 p.m. - at the 8-second mark, you can literally hear the shudder through the car after a big bump. Then, the problem resolved itself and at 4:45 p.m. - same day, same commute, even the same road - there isn't that shuddering impact after a similarly big bump. I remain mystified.
    4:39 p.m. - shudder at 8-second mark.
    4:45 p.m. - no shudder over a similar bump.
    Peoria, AZ
    With such shudder, it has to be something obvious if you were to look at suspension components.
    On vid 1 you were turning, on vid 2 you were traveling straight. I'd start with the easiest - tie rods.
    Stupid question: you've checked your wheel lugs recently, right?
  1. E39 Steering Wheel Mania! Non-Sport E39 with Air Bag
    By Les Goeforitt in forum Interior Lighting & Body Parts
    Last Post: 10-19-2010, 08:53 PM
  2. E39 2000 BMW 528i 5 Speed Manual 157k Sport Premium E39 with 20+ Pics
    By HiFIVE in forum 5 series & 6 series
    Last Post: 08-07-2010, 08:46 PM
  3. e39 hellas with Bi Xenon?
    By jdjg in forum 1996 - 2003 (E39)
    Last Post: 02-05-2009, 03:39 PM
  4. E39 FS: Dice Ipod integration kit for e39 with dsp
    By NegativeCamber in forum Car Audio & Electronics
    Last Post: 05-30-2008, 02:39 AM
  5. Replies: 5
    Last Post: 12-23-2007, 05:09 AM
