Results 1 to 24 of 24
Thread: M Coupe Airbag Module: anyone know of a good place to find one?
    Aug 2015
    Santa Barbara, CA
    '02 330i
    Mine's bad so I'm looking for a replacement, either 65778386192, or 65776908896. I found and original one on eBay, bought it, but it's no good. You guys probably know the story on these: they go bad and that's it for the airbag system.
    The best place to find one is one this forum, from someone parting out their car. I'm open to any ideas, thanks.
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Put a WTB ad in the race cars and track parts classified section. I threw the airbag module in my E36 away and I think most people building racecars do the same.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    There's someone that just posted they're parting out an M Coupe on the M Coupe Facebook page right now
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    Based on those part numbers, it looks like Z3 and E36 modules would also work -- and would be much easier to source. From Real OEM:
    65776908896
    RP control unit airbag, uncoded RP control unit airbag, uncoded
    Superseded by:
    65776910677(08/20/2001 — 08/13/2002), nonexchangeable retrospectively
    65776922954(02/25/2002 — ), Exchangeable retrospectively
    Supersedes:
    65778386192(03/01/1999 — 07/14/2000), nonexchangeable retrospectively
    65778386131(09/01/1998 — ), Exchangeable retrospectively
    65774149976(03/01/1998 — 04/16/1999)
    Part 65776908896 was found on the following vehicles:
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Curious what is going bad?
    /.randy
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by OCRentAPopo View Post
    65776908896
    Superseded by:
    Supersedes:
    Careful, this doesn't mean that the old E36 modules (plenty at the junk yards) will be compatible with Z3.
    This just means that the new module version has compatibility to both.
    MRSZ3 and ZAE modules (+ others) do not mix.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Mine is toast as well, I was just going to search the part number on eBay.
    I'm pretty sure you need to code it as well after install. I could be wrong.
    Aug 2015
    Santa Barbara, CA
    '02 330i
    Quote Originally Posted by rf900rkw View Post
    I've had Error 240 ECU Fault forever. The replacement module, purchased used on eBay, has it also. The Seller says he can replace it, which is very accomodating since I bought it in March 2017 and just got around to installing it (which is a real PITA without removing the whole center console).
    Quote Originally Posted by fallguy View Post
    Yes, the Diagnostics thread originated by good ol' "328 Power 04" tells you how to code it. I did try it on the replacement module I got and got a bunch of warnings and exclamations in German, which I do not understand. I assumed that it was telling me that the module was not code-able because the module had the Error 240 fault.
    It's the last of many vehicle functional repairs I've performed and I'm hoping to finally get that airbag light cleared on the dash...and have working airbags.
    Quote Originally Posted by Randy Forbes View Post
    Thanks, that's great info.
    I thought we needed a brand new one. We just need a module from a z3 that didnt have an airbag light or deployed airbags?
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    Let me look through my pile of random parts from the last car I may have one sitting around.
    Is it ok if I had a driver side bag deploy or does that make it bad??
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by Z3speed4me View Post
    Usually 1 deployment should be OK.
    If it's locked up due to a deployment (normally takes 3), I can easily clear out the data.
    There are no wear parts inside the module.
    (*I don't remember if I bought my used module from you, or someone else. I think mine was out of a 2000 Z3M.)
    -Abel
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Mine also has an internal fault DTC. I haven't replaced it yet because right now the new module is about $1k. I don't think it's repairable, so if you wanted to open mine up I could probably send it if I ever got a replacement.
    Aug 2015
    Santa Barbara, CA
    '02 330i
    Quote Originally Posted by LannVouivre View Post
    Right, the price for a new module must be following Google stock price as it went from around $500 a few months ago up to over $1k. I suppose the market is not demanding so the value rises. I am curious about what the actual fault is. A good electronics guy with the schematic and a diagnostic tool could probably figure it out.
    Quote Originally Posted by wallball View Post
    I'll have to talk to my economics teacher about this "low demand, rise in value" theory of yours...
    My S52 only had the driver's airbag deploy. Abel, want to help me with this coding stuff? I'll have the laptop tomorrow
    PRICE CUT on ALL FABRICS
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes sure thing, let me know a little ahead of time.
    -Abel
    Aug 2015
    Santa Barbara, CA
    '02 330i
    Quote Originally Posted by BimmerBreaker View Post
    It makes sense from a Production standpoint: only a few needed and made, means higher production cost, hence higher price. Otherwise it's just plain old greed!
    Aug 2015
    Santa Barbara, CA
    '02 330i
    I tried coding the module again and it gave me errors as shown below. Anyone know what they mean(regarding the airbag module). Screen Shot 2017-07-02 at 7.38.45 PM.png
    Jul 2004
    Houston, TX
    36 Cylinders
    Is this the module with the internal error?
    I don't believe module itself will let you code it.
    -Abel
    Aug 2015
    Santa Barbara, CA
    '02 330i
    It's the replacement module that I recently installed. I coded it using NCSExpert and followed your instructions. After pressing "Execute Job," I got some warning window that told me to look in the ERROR.x file or one other one. The page I printed above is what was in the ERROR.x file, dated today when I was trying it out. Did I do something wrong (I hope)? I don't understand your second sentence.
    Jul 2004
    Houston, TX
    36 Cylinders
    I was intending to say that a module with an internal error fault will not allow coding. So you do not need to think it's a connection problem.
    I wonder if there is a short in the car that killed the 2nd module?
    On my 2000 roadster, the error appeared right after plugging in a driver's seat belt tensioner thar I was given from another Z3. Turns out that Z3 was a 2001 falling under the newer part revision. Learned my lesson on that one. Wires were different.
    -Abel
    Jan 2016
    Ca
    2001 525it
    The dealer and let a shop code it
    Aug 2015
    Santa Barbara, CA
    '02 330i
    A short is possible, of course, and shorts are not always easy to find; if the wiring is different, that's a killer. I'm not sure that the Seller was 100% certain that the 2nd module was good when I bought it. It came from a crashed roadster that was hit in the left rear quarter panel and the airbags had not deployed (I saw pics). So it could have been bad prior to the crash. The crash damage was not bad at all, so I was thinking that the bags did not deploy because of the limited acceleration. The Seller is sending me a replacement module that he will "test" somehow and make sure it's good.
    Any idea what the ERROR.x errors mean?
    Jul 2004
    Houston, TX
    36 Cylinders
    You have error 1006, and 1009. Which incidentally don't seem to be defined in the COAPIERR.txt file , but Errors 1000-1019 fall under "General Errors".
    Those errors are likely because the module is rejecting coding, just like when it rejects clearing errors when "Internal Error" is present.
    -Abel
    Jun 2016
    Odessa, TX
    1. I do realize that this should be pretty obvious, but I just want exchangeable vs. nonexchangeable retrospectively explained in a way that gives a reference point. When it gives a nonex or ex note, which unit is it referring to? Is it that the new part can be used to replace old parts (exchangeable) with no compatibility issues?
    2. It seems to be p/n
    65776908896 got superceded and discontinued recently or something, because I don't remember it having a "superceded by" list on realOEM. I think they have stopped production and that's what caused the (massive) price increase. It looks like originally there was 65778386192, which was superceded by 65776908896, which was superceded by 65776922954 in turn.
    3. My current module is this one (via actually checking the one in the car now):
    https://www.realoem.com/bmw/enUS/par...&q=65778386192
    I'm assuming that my only replacement options are another 65778386192 that may have the same problem and is also really rare, or the 65776922954 that HOPEFULLY has actually managed to resolve the problem.
  1. anyone know of a good place to get springs/shocks
    By hifocused in forum 1991 - 1999 (E36)
    Last Post: 01-16-2007, 10:45 PM
  2. Anyone know of a good place to buy ASA AR1 wheels?
    By hifocused in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-14-2007, 12:51 PM
  3. Replies: 0
    Last Post: 02-06-2002, 01:22 AM
