Results 1 to 7 of 7
Thread: Yo dawg what rear spring rates should I get?
    Feb 2010
    Chapel Hill, NC
    1985 535i
    Hey guys. I'm about to order new coilovers (Fortune 510s) and get off these Raceland Ultimos I've been rocking for two years. The only issue is. I'm going from a progressive to a linear spring and my current setup is softttttttt (see picture below.) I can vaughn gooter like nobodies business right now and it's sick. I really like being able to feel the rear of the car squat, dig in, and take off. That being said. I'm ordering coilovers and SLR and wanted to see what kind of rates the N/A dudes were running. or what rates you think would allow me to continue gootering. I actually really like these racelands. I have them all the way up in the front and I swapped out the rear springs for some tein progressives. From what I read they're 350-700 progressive rate. Which translates to really soft. Especially as they are super old and also off of an e36 and pretty rusty. I honestly would stick with this setup because I actually really like the way it drives. But unfortunately the Racelands are drooping about an 1/8" after every event in the front and the rear shock bushings are about to blow out of them. (They really shouldn't be drifted on ever)
    Anyway thanks for the input.
    Pic of said Gootering
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    the fortune website has a form for you to fill out and their spring expert will recommend you the correct ones for your setup
    BALTIMORE
    700# springs, in the rear, is what I've mostly seen on the internet. It's what I went with and I was quite pleased with how my car drives. That's for stock power though. Apparently the big power boys are running springs in the 400ish pound ballpark
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Fortune told me to run 10k front / 8k rear with a 420whp LS swap
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    I am at 8K front 12k rear on AST 5100's with SLR and no sway bars. Worked well when I was N/A but with boost im going to drop down to an 8k in the rear. My car never pulled the front wheels or anything but it felt really damn good
    Aug 2011
    philadelphia PA
    1993 325is
    Depends how much power you make, how much grip you want, and how you drive.
    I run 8k and keep the dampers pretty soft. With a 245/40/18 @20psi cold I can keep up with most cars.
    Remember that our rear springs aren't direct acting like the macphearson fronts, so rear wheel rates are a fraction of the actual spring rate.
    Feb 2010
    Chapel Hill, NC
    1985 535i
    Quote Originally Posted by Gmfwd View Post
    I ended up going with 10k front 8k rear BCs. We'll see how it plays out. I'm aware of the insane rear motion ratio on e46/36. I guess I'm just used to a really soft rear rate. I like feeling the car squat and bite.
  1. Yo dawg what rear spring rates should I get?
    By Jrcanes55 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-26-2017, 08:08 PM
  2. Touring what rear springs should be in there?
    By Mless5 in forum 1996 - 2003 (E39)
    Last Post: 10-22-2010, 05:02 PM
  3. What spring rate should I get with TCKR True Match S/A Coilovers
    By abtmuda in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-14-2005, 10:07 PM
  4. What shock/spring combo should I get and where?
    By yellowbullet in forum 1995 - 2001 (E38)
    Last Post: 05-03-2004, 10:52 PM
  5. Rear spring rates H&R vs Eibach prokit
    By m3lawdawg in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2003, 11:50 AM
