Results 1 to 2 of 2
Thread: Covertible Top Will Not Close Manually
    Jun 2017
    Burton, Texas USA
    2001 BMW 330i C
    The top on my 2001 330ci will not close manually. I have followed all the directions in the manual as well as watched numerous vids on the subject. The issue is that it will not lay flat near the windshield so that I can manually secure the top with the allen key. The top is pointing up at a 45 degree angle and the allen key does not lower the top so that I can secure it. Any DIY suggestions other than taking it to a shop?
    thanks,
    Mark
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    you have to crank and crank and crank till your arm falls off with the allen key. it will close eventually. we cut the key off and put in a drill and used it that way (but do this at your own risk)
    Level 1 Certified BMW tech.
  1. Top will not close
    By JohnWM in forum Convertible Questions
    Last Post: 06-03-2010, 05:48 PM
  2. My 94 325i vert top will not close
    By briang0 in forum Convertible Questions
    Last Post: 08-04-2009, 09:49 PM
  3. Top will not close It barelt catches on convert lid
    By ccwhit7 in forum Convertible Questions
    Last Post: 09-12-2008, 02:43 PM
  4. Top will not close, light turns red when button is pressed.
    By adam699 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 05-05-2008, 05:34 PM
  5. HELP ... top will not close completely
    By maxburn84 in forum Convertible Questions
    Last Post: 04-24-2007, 01:23 PM
