Hi all,
When I try to use the washer, it wont come out nor would I hear any other sound from pump. I thought it might be a fuse. I looked at the fuse chart and for my car it's fuse 84. Unfortunately, where fuse 84 suppose to be is an empty space and it does not appear it held any fuse before.
Also, I cannot figure out which fuse is meant for the lighter/charger that is in the middle of the car under the arm rest.
Any help is much appreciated.
Thank you
my winshield washer fluid pump went and I remember reading it's a common issue with these cars, so might be the pump, they're pretty cheap I think
Thank you for replying back to me.
I'll try to replace the pump as I hear no sound. Is there a guide on how to do this?
Check the voltage at the pump before you go and replace it...
Total Noob here. How can I do that? :/
Just bought my son a 2006 330i. Washer reservoir indicated low so put fluid in. Pump sounds like it runs but hardly any fluid comes out. Any ideas?
If the pump runs, and hardly any fluid comes out, the strainer is clogged with algae.
