Hi Guys,
I had a yellow engine error message come up on my car, i ran my mates carley on it, deleted all the error messages, ran the car until the yellow engine warning light came on these are the error messages left can someone explain them?
Carly for BMW - detailed Fault-Code Log
Found Faults:
--Engine / Motor--
*** 4CAE:Low-pressure exhaust gas recirculation actuator position sensor signal circuit or short to ground ***
Fault-Set 1 - ( 105704 km)
Activation period for the main injection 1: 966.82 us
Current Motorabstellzeit (2 bytes): 169770.00 s
Current value of accelerator pedal signal 1: 3085.94 mV
Exhaust backpressure before particulate filter - corrected: 3188.00 hPa
Exhaust gas temperature before catalytic converter - corrected value (1 byte): 69.22 degC
Filtered flow resistance of the particulate filter: 0.01 hPa/(m^3/h)
HFM-shutdown: 5.00 -
Injection amount PoI2 before correcting the fault monitoring: -86.73 mg
Injection type injection place specifications: 82.00 -
Kraftstoffvorförderdruck - Spannungsrohwert from the sensor (1 byte): 123.53 mV
Linearized error untreated ATL actuator position (1 byte): 0.39 %
linearized value of the fuel pressure sensor: 5710.00 bar
MoCSOP_ctErrMM_mp 1: 141.00 -
MoCSOP_ctErrMM_mp 1: 175.00 -
MoCSOP_ctErrMM_mp 1: 66.00 -
MoCSOP_ctErrMM_mp 2: 33.00 -
MoCSOP_ctErrMM_mp 3: 128.00 -
MoCSOP_stMm_mp 0: 0.00 -
MoCSOP_stMm_mp 1: 0.00 -
Offset of particle filter differential pressure (1 byte): -28.63 hPa
regeneration status: 2460946432.00 hex
Ring memory with the last 8 Reset IDs 1: 22399.00 -
Ring memory with the last 8 Reset IDs 2: 7708.00 -
Ring memory with the last 8 Reset IDs 4: 51.00 -
Fault-Set 2 - ( 32768 km)
Activation period for the main injection 1: 0.00 us
Current Motorabstellzeit (2 bytes): 291840.00 s
Current value of accelerator pedal signal 1: 0.00 mV
Exhaust backpressure before particulate filter - corrected: 33.00 hPa
Exhaust gas temperature before catalytic converter - corrected value (1 byte): 162.35 degC
Filtered flow resistance of the particulate filter: 0.00 hPa/(m^3/h)
HFM-shutdown: 0.00 -
Injection amount PoI2 before correcting the fault monitoring: -99.80 mg
Injection type injection place specifications: 0.00 -
Kraftstoffvorförderdruck - Spannungsrohwert from the sensor (1 byte): 0.00 mV
Linearized error untreated ATL actuator position (1 byte): 0.00 %
linearized value of the fuel pressure sensor: 0.00 bar
MoCSOP_ctErrMM_mp 1: 0.00 -
MoCSOP_ctErrMM_mp 2: 0.00 -
MoCSOP_ctErrMM_mp 3: 76.00 -
Offset of particle filter differential pressure (1 byte): -100.00 hPa
regeneration status: 32640128.00 hex
Ring memory with the last 8 Reset IDs 1: 0.00 -
Ring memory with the last 8 Reset IDs 2: 0.00 -
Ring memory with the last 8 Reset IDs 4: 0.00 -
*** 4DFB:Motorabstellzeitermittlung ***
Fault-Set 1 - ( 105712 km)
Activation period for the main injection 1: 1154.93 us
Basic boost pressure setpoint value (low-pressure stage): 32784.00 hPa
Current Motorabstellzeit (2 bytes): 589420.00 s
Current value of accelerator pedal signal 2: 0.00 mV
Exhaust backpressure before particulate filter - corrected: 0.00 hPa
Exhaust gas temperature before catalytic converter - corrected value (1 byte): -50.00 degC
Exhaust gas temperature before particulate filter - corrected value (1 byte): -50.00 degC
ID 2 for synchronization in the function monitoring: 0.00 -
Injection amount PoI2 before correcting the fault monitoring: -100.00 mg
Injection quantity - quantity setpoint without compensation scheme (1 byte): 0.00 mg/hub
Linearized error untreated ATL actuator position (1 byte): 29.80 %
MoCSOP_ctErrMM_mp 3: 143.00 -
MoCSOP_stMm_mp 0: 66.00 -
Offset of particle filter differential pressure (1 byte): -49.02 hPa
Performance EKP (U * I) filtered (1 byte): 1.00 W
Rail pressure - Command value (1 byte): 501.96 bar
regeneration status: 2058322048.00 hex
vehicle speed: 0.00 km/h
cheers
Ed
