Hi,
I was trying to bleed my brake fluid, but when I unscrewed the bleed valve a half turn, no fluid came out.
Even when I took the bleed valve out, still, no brake fluid. So, it must be clogged up somewhere.
Any ideas on how I can locate the problem and how to fix it?
Sounds like the same problem I had.
https://www.bimmerforums.com/forum/s...d-is-important
______________________________
1992 750iL
Try removing the line leading to the caliper and seeing if you get fluid there. If you do, then you know the caliper is blocked up. Sometimes, tapping the caliper with a mallet is enough to loosen the blockage. But usually, it means you have to either rebuild or replace the caliper.
1989 750iL schwarz/schwarz
1991 M5 schwarz/silbergrau
2013 328i coupe diamondschwarz/caramel
2003 525iT orient blue/tan
1990 535i/5 schwarz/schwarz
Yeah, that's what I was afraid for. I hoped I could fix the problem without disconnecting the line leading to the caliper or the caliper itself.
It won't be an 1 hours job
Thanks for the reply and foto's of the caliper!
Just to be a step ahead,
What if the caliper isn't the problem, but what if the line itself is blocked?
How do I clean that?
