Results 1 to 6 of 6
Thread: Best correct code reader for e46?
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    I bought an OBII code reader on-line..$22 for my Audi back in 2007. As I discovered soon after, it did not actually read codes, but instead did erase codes! So when my Audi was scheduled for emissions inspection, I would erase codes some 40 miles before driving into the inspection bay! It has worked this way for me for 11 years. My Audi always passed!
    Code reader sellers of less than honest may still lurk...knowing this, I want a real code reader for my new-used 325xi.
    Is there a 'real' code reader available for this BMW car that is under $300, a real deal code reader giving real info for the 325xi?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    You own a laptop with a USB connector? http://www.ebay.com/itm/BMW-K-DCAN-O...oAAOSwHMJYCDyh
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Sep 2010
    romania
    golf
    Hello, there are lots of tools dedicated for bmw under $300, actually for your model you can get a very comprehensive pack at around $30-$40.
    Not only that you can diagnose it and see live data but you can enable different features by coding it with NcsExpert, for example you can enable/disable DRL's, lock doors after a certain speed, fold mirrors from keyfob if you have folding mirrors, roll windows up/down from keyfob and so on.. here is an example how it's done: https://www.youtube.com/watch?v=nZqfl_dz0xM
    good luck!
    Feb 2017
    Metairie, LA
    2001 325i; 2006 325i
    I have one of the cables mentioned above, but am still working on getting a laptop setup to use it. I'm sure that it will turn out to be the best option for doing anything and everything that might need to be done. I also have a Carly unit, which is wireless and works in conjunction with an app (IOS or Android). It works pretty well when it comes to reading codes and doing basic coding. I also have a Foxwell NT510, which is a self contained handheld reader which will read and clear OBDII and BMW specific codes. It also has the capability to code/register new parts, clear adaptations, etc.
    I really can't comment on using the cable with a laptop yet, but from what I've seen, it is going to be the most difficult to setup (for those that have never done it before) and the least convenient to use.
    The Carly, in theory, comes across as being convenient to use, but I've found it to be a bit of a pain to actually use. You have to change the wireless settings on your portable device to connect to it and once you're connected, you can't access the internet to look up what the scanner is telling you. I also paid extra to be able to reset service intervals, but that option does not work with my car for some reason and tech support has been no help in resolving the issue. All they've told me is that not all options work on all cars.
    Of the two handheld options I've tried (Carly and Foxwell) the NT510 has worked the best for me. It's easy to use, does what it should in terms of reading and clearing codes and I've used it to reset adaptations. You just plug it in, it powers up and you use it. I've found it to be much more convenient than the Carly. The downside is that tech support is a bit iffy because support comes from people that really don't speak english. It hasn't been a problem for me because I haven't needed tech support yet.
    Both the Carly and Foxwell NT510 cost under $200.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I use the OBDFusion app on my iPhone. The app cost $10 ($4 for the android version). iOS uses a wifi communications adapter while android products use a Bluetooth adapter. The adapter plugs into the obd2 port. OBDFusion allows you to read and clear codes (natch) and to log data that can be exported for analysis on a conputer. Go to E46Fanatics and search for threads on OBDFusion in in which jfoj has commented. He's the guru. Best ~$25 I've ever spent.
    CT
    E28, E32, E39, E53, E90
    I have used this Actron pocket scan tool for the last 5 years or so. It doesn't do the more advanced codes, but you can probably get it locally for $50 or less at an Autozone or Advanced auto parts.
  1. E46 Bentley Manual & Peake Code Reader for sale
    By easport in forum Middle Atlantic - US
    Last Post: 11-01-2010, 01:39 PM
  2. Code Reader for E46?
    By Chris Huff in forum Georgia sponsored by Harrison Motorsports
    Last Post: 09-27-2007, 09:47 AM
  3. Need Good Code Reader for both OBD I and II: Suggestions?
    By fun2drive in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-29-2004, 08:59 AM
  4. Best replacement/upgrade seats for E46?
    By AlphaDog in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-20-2004, 08:24 PM
  5. Best Component Set-up for E46 coupe?
    By asif2002 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-09-2004, 12:22 PM
