Results 1 to 6 of 6
Thread: Safe to drive e46 105 km without Outside Temperature sensor?
    Aug 2013
    Vancouver, BC, Canada
    2004 Bmw 325i
    Sensor is gone. Copper wire is partly shredded I suppose(or exposed). A 2-4km drive to the nearest store to buy tape would fix it up.
    I'm stuck 105km away from my home. Will I damage the engine if I drive without this sensor or should I just call a tow truck. AC seems to be working fine for now...
    Bellevue, WA
    335d, 328xd (had 330xi)
    Quote Originally Posted by RDyn View Post
    I wouldn't worry about it; ECU will probably run the default fuel/air map, which is conservative. The ECU also has other sensors (knock sensors) to watch for badness.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The ambient air temperature sensor is not involved in the engine management scheme. It's purpose is to inform the automatic climate control of the external temperature. The missing sensor will impact the operation of the AC. Repair kits are available from the dealer and online vendors.
    The engine management computer (DME) receives intake air temperature data from either a sensor in the intake manifold (early E46s) or the temperature sensor in the MAF. The MAF, in the latter instance, has 5 pins while the earlier MAF has 3 pins.
    Jan 2016
    Ca
    2001 525it
    Yes it is ok to drive, the very late e46 cars tied the outside temp sensor in to the dme so a check engine light could appear it you had that in your car.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    Outside ambient temperature sensor and gauge failure, would not, and should not, ever effect essential drive systems, nor should other non essential drive mechanisms that may fail. In a third world maybe!
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    yes we would have customers that drove with sensor torn off for years before fixing...
    Level 1 Certified BMW tech.
  1. Replies: 3
    Last Post: 03-10-2014, 06:09 PM
  2. Is it safe to drive without emergency switch/sensor? (61318350284)
    By thisdavidg in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-11-2010, 10:48 AM
  3. Replies: 1
  4. Is it safe to drive without a front stabilizer (sway bar)?
    By Marc in forum 1992 - 1999 M3 (E36)
    Last Post: 05-31-2008, 09:57 PM
  5. Bent wheel safe to drive high speeds?
    By Chongus in forum 1992 - 1999 M3 (E36)
    Last Post: 01-18-2003, 12:10 PM
