Results 1 to 5 of 5
Thread: 1989 e30 325i automatic transmision oil leak
    Los angeles, CA
    80 323i, 89 e30C,11X5
    My car is leaking tranmision fluid where is the leaking coming from? Is a difficult repair? Thanks, for your help.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Usually there are 3 points which leak, provided the trans pan gasket is not leaking: input shaft seal, output shaft seal and the small seal on the side for the selector shaft seal.
    So first you have to see and check where it comes from. In case it is the input shaft seal, then the ATF comes out at the bottom of the bell housing thru the plastic vent. Input shaft seal change requires removing the transmission.
    Aug 2016
    South FL
    1994 Miata
    Power steering system also uses ATF so you'll need to check that too.
    Los angeles, CA
    Thank you so much!
    Jun 2015
    Santiago, Chile
    Audi A4 , Grand Cherokee
    Resurrecting this one...
    My e30 325i auto transmission is leaking and I can see it is not the Shifter seal. I do have a leakage thru the Pan Gasket but I believe I might also have a leakage thru the Input Seal. I have some seapage coming from the plastic grill area, so it makes me suspect the Input Seal might be bad, not sure.
    I am thinking about doing the Pan and Filter first, then keep driving and if leakage continues, I can attack the Input Seal. This way I avoid removing the Transmission, in case it is just the Pan.
    Question: to do the Input Seal later, will I need to drain the Transmission Fluid again, or can I do Pan now and Input later?
    Thanks in advance
  1. E30 FS: E30 325i Automatic Trans with 40-50 miles(Brand New) $1000
    By kartikchandar in forum Drivetrain & Transmission Parts
    Last Post: 10-06-2010, 02:57 PM
  2. E30 FS: 1989 E30 325i GA
    By CosmoE36 in forum 3 series & Z Series
    Last Post: 09-24-2010, 01:30 PM
  3. E30 FS: 1989 E30 325is (Michigan)
    By woodypup in forum 3 series & Z Series
    Last Post: 06-01-2010, 10:28 PM
  4. E30 FS: CA: 1989 E30 325I Vert for $2200!
    By Jo@EuroDyne in forum 3 series & Z Series
    Last Post: 05-11-2010, 12:54 AM
  5. 1989 E30 325i Automatic - $690!
    By themadhatter in forum 3 series & Z Series
    Last Post: 09-10-2008, 02:41 PM
