RM European Auto Parts
Results 1 to 6 of 6
Thread: E36 electric fan convertion!
    Nov 2016
    texas
    1998 328is
    Hello everyone I was lucky to find a 98 323i in a junkyard with a electric fan attached to the radiator which I got for 50$. It's now in my garage and know how to swap radiators but I think I want to keep mine. I know how to swap the fan over but one problem I'm having is where do I connect the fan connecter? I'm not too good with wiring but I'll attach a pic and someone can help me of what's the easiest option to do. I want it to be on most of the time so I'm not taking out the fan in front of ac condenser.
    And let me know if this is a good idea to do to replace the mechanical fan that is driven by the motor. IMG_20170624_195705790.jpg
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    Jan 2016
    Ca
    2001 525it
    If the fan clutch is in good condition there really is no reason to but in the electric fan. Personally I kind of like the mechanical system, because if the electric fan stops working then you have nothing
    Nov 2016
    texas
    1998 328is
    Quote Originally Posted by jclausen View Post
    I know but I want to go electric to reduce the noise of the fan spinning and less stress on the motor
    Dec 2004
    Huntsville, AL
    87 325is
    The engine driven fan moves more air than the A/C condenser fan. If you have only the A/C condenser fan the engine will probably over heat at low speed or when stopped and idling.
    Jim Levie, Huntsville, AL
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    agreed - can't see much reason to do this myself. sure, on a track car - but, something that sees significant street time - no need.
    Dec 2004
    Huntsville, AL
    87 325is
    Also if the fan clutch is good there is hardly any load on the engine when the fan isn't needed. You can easily stop the fan with you hand when the clutch is not engaged.
  1. E36 Electric fan
    By DueceFever in forum BMW Parts For Sale
    Last Post: 12-01-2006, 12:13 AM
  2. e36 electric fan, radiator support (sedan), and condenser
    By Ahmet in forum BMW Parts For Sale
    Last Post: 11-21-2006, 05:21 PM
  3. E36 Electric Fan Blade
    By RJ's325ITS in forum BMW Parts Wanted
    Last Post: 11-11-2006, 04:30 PM
  4. Does anyone have an E36 electric fan?
    By LTrain in forum Middle Atlantic - US
    Last Post: 05-24-2006, 05:14 PM
  5. E36 Electric fan ?
    By Infuriatus in forum 1991 - 1999 (E36)
    Last Post: 01-24-2006, 04:27 PM
