Okay so I got this car in a trade... 2000 328CI
DTC button doesn't work, nothing comes on when I turn it on like no DTC light. I checked the fuses they were ALL good. I then pulled the switch out and nothing looked burned on the board.
My guess is a bad pump/module.
Any advice would fantastic
Assuming that you meant DSC. The lights (abs brake and dsc) should all come on and go off when ignition switch is on. If that works then the problem is most likely the button/switch.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Yeah I meant DSC realized that right after I posted...
Brake light works like it should
ABS light was on till I drove down the street it went off
However the triangle light never came on when I started it up.
You should check if there are any codes in the dsc module
Got an old xp laptop? BMW scanner 1.4 is only $15 and easy to install and use.
If I were to give my Touring a first name, I'd probably name it "Alan".
Mostly because I like puns.
Mutual Admiration Society #5
Or Bcables.com
You can download everything you need software wise there, and just find an OBD II cable with a USB plug end on it for the laptop.
2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
2003 M3 - 210K - BMW Euro Cross Drilled Rotors
