Results 1 to 16 of 16
Thread: Coolant expansion tank, custom holding bracket
    May 2012
    San Diego, CA
    1996 BMW 328is
    After replacing the fan clutch with an electric fan many years ago, I finally cleaned up how the expansion tank was mounted.
    See before and after photos. All of the extra plastic is removed, and much cleaner look and function.
    If you are interested in getting one made for your car....
    For $10, I'll send you a PDF of the engineering drawing, so you can take that to a machine shop. I am just looking to recoup my time & effort.
    For materials, I gave the machine shop an aluminum L bracket...the L was 4" x 4" x 1/2" thick. The L was 6 inches long. I bought a 12" long piece for $33.
    The machine shop made two pieces, but I only need one.
    For $90, I will ship the second one to you, shipping included to lower 48 states.
    The current hole in the bracket is a thru hole for a M6 x 1.0 thread x 20mm long bolt.
    Your radiator may be different.
    PM if interested, and PayPal payment instructions.
    Brian
    Feb 2016
    South Africa, JHB
    1992 BMW 325i (Drifter)
    I like it !
    Jan 2013
    Plano, Texas
    1989 325i
    That thing is awesome, I need one
    Jun 2017
    4x4
    looks nice
    Mar 2014
    Denver, CO
    1995 325 is
    Very nice, the expansion tank mounting won't ever need to be dealt with again on that design.
    With this setup one would need to completely remove the fan shroud, is that correct?
    Also trying to think how this would be mounted to the stock radiator that uses the plastic pop-rivets....
    May 2012
    San Diego, CA
    1996 BMW 328is
    FamilyForce6
    Yes, the fan shroud is completely removed now, after the installation of the aluminum tank bracket discussed here.
    Prior to the custom aluminum bracket, I had cut the fan shroud after installing an electric fan, to where only the section near the coolant expansion tank remained.
    With the electric fan installation, I also put in an aftermarket radiator.
    Blackworks RAD-BM01
    http://www.aptuned.com/RAD-BM01
    I used a threaded hole to mount the plastic to hold the expansion tank (shown in the "before" photo), but the whole expansion tank was being held up solely by the bleed screw. Not good.
    It worked for a while, but time to get a permanent solution, so the aluminum bracket.
    On your other question, I haven't had a stock radiator in such a long time, I wouldn't be able to help you there. Sorry.
    Brian
    May 2012
    San Diego, CA
    1996 BMW 328is
    This also fits Mitshimoto radiators.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Props dude!
    May 2012
    San Diego, CA
    1996 BMW 328is
    Back in 2017, two years ago, I had two of these brackets made.
    I can now see that I'll never use the second bracket. I have had no issues with the first bracket, and it has been in my E36 the whole time.
    I'm accepting any donation for the second bracket, plus you pay shipping.
    If you want to donate $0, then you pay only shipping. I ran a few errands, designed it, and paid for it, so donations are appreciated.
    I am old school, so PayPal or Zelle works for me.
    Also, I have no idea when you ask me, "How much is shipping to XXXXX zip code?"
    I will front the shipping costs, and send you a photo of the shipping receipt. I just put the bracket on a scale, and it weighs 1 pound.
    Brian
    San Diego, CA
    Jan 2020
    New York City
    1999 M3
    Hey man interested if you still have those brackets but would you be able to send me some pictures so I can see what it looks like?
    May 2012
    San Diego, CA
    1996 BMW 328is
    Josh488,
    On the first post of this thread, there are photos.
    I checked my garage, and I no longer have this.
    If you would like, I can send you drawings so that you can get it made.
    PM me if interested.
    Brian
    May 2012
    San Diego, CA
    1996 BMW 328is
    Here's the drawing of the bracket.
    It took me a lot of time, but many people on this site also donate a lot of their time.
    If you would like to send a donation, PM me. If not, no big, and enjoy.
    Brian
    Nov 2005
    Finland
    Z3 Coupe individual
    Quote Originally Posted by Brian 328is View Post
    Brian
    Hello, thanks for the image, but I cant understand any measurement, they are fractions of an inch?
    you dont happen to have the expansion tank bottle hole width and lenght and just r for corners. If possible in millemeters/metric.
    Z3 & E36 RamAir systems, send private message for more information.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Those dimensions are in "thousanths", so 1.250 would read "1 inch and 250 thousanths", or 1-1/4 inches. You can use google to translate into mm.
    Nov 2005
    Finland
    Z3 Coupe individual
    That’s what I thought.
    2 PL and 4 PL meaning what? Propably does not matter...
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    2 pl reads "2 place", refers to how many places shown to the right of the decimal point. Example: 2.50 is 2 pl ..... 3 pl would be 2.500, which is generally more accurate than 2.50 (although accuracy for both should be defined. Example: 2.500 +/- .005 )
  1. Euro Coolant Expansion Tank Bracket
    By Pink in forum 1992 - 1999 M3 (E36)
    Last Post: 09-20-2015, 07:50 PM
  2. 99 323is coolant expansion tank removal Question
    By Graffix000 in forum 1999 - 2006 (E46)
    Last Post: 05-29-2008, 02:15 PM
  3. Replace? coolant expansion tank, cap, bleeder screw...
    By old skool in forum 1991 - 1999 (E36)
    Last Post: 03-24-2005, 08:56 AM
  4. Coolant Expansion tank~
    By keoaloha in forum 1988 - 1996 (E34)
    Last Post: 07-15-2004, 04:04 PM
  5. E36 coolant expansion tank & cap
    By nat325i in forum BMW Parts For Sale
    Last Post: 01-18-2004, 05:51 PM
